grease on headliner
  • grease on headliner
    Anyone know a way to remove grease from a headliner?
    When I was putting in some rims into the back seat
    I accidently bumped into the ceiling...
    Material is a sort of cloth
    Car is a PT Cruiser '04
    Damage is a 2" straight black streak on a tan interior...
    Thanks in advance
    Glen
    what kind of grease? wheel bearing grease? or just dirt with brake dust?
    If its actually grease, I would take some paper towel and lift most of the grease. Then I would use some interior fabric cleaner and spray in to the headliner. Let it soak a bit and with a towel just let it absorb it by pressing on it. I would not recommend rubbing it at this point since you might smear more grease into the headlinner. Once most of the grease is out then you can try rubbing it at the edge to see if it got cleaned. If not repeat the process a couple more time.
    Life is a journey, enjoy the ride!
      Best grease remover I've ever used on clothing is Dawn dish detergent....never used it on a headliner but it's cloth so it may work...gentle is the key word here...do not rub too hard !!
      Bill Poirier
      West Seneca, NY 14224
        When I got my new car, it had a little grease on the headliner. At least it looked like grease.
        I got the Heavy Duty Carpet and Interior cleaner. Sprayed on a terry cloth, and dabbed till it was gone. Didnt take more than 5 minutes.
        Heavy Duty Carpet & Interior Cleaner
          Try the mild stuff first but if all else fails here's one that always works for me. Automotive Brake Cleaner is for all practical purposes the same as dry cleaning fluid. I've used it to remove some stubborn stains from carpet. Don't know about headliner though. Sometimes the boards are foam and I don't know what it would do to the foam. Test on an incomspcious place first.
          Alan Minga
          86 T-Type The white car.
            Hmm, I guess I don't really know if it is grease, brake dust, dirt, or probably a little bit of it all...
            It's not gooey like a wheel bearing grease,
            but coming from the rim of a tire,
            So probably more like dust, and dirt...
            I'll try to post some photos...
            Glen
              Glen
                photo 3
                Glen
                  I'd still try a little Dawn and warm water first....
                  Bill Poirier
                    Yeah, looks like mine did.
                      Looking at the pictureds, its not that bad as I believed. Yes use some carpet/interior fabric cleaner. Just be gentle.
                        Well I finally got hte Meguiars carpet cleaner.
                        It is fantastic !
                        The dark stain completly disapeared.
                        I highly recomend it.
                        Glen
                          Add Content
