Will plastix on polishing pad & a DA work to clean up black plastic mirrors. They are also etched with the bugs. Have used #83 & a DA seemed to work the best for me. Plastix won't touch it by hand. Just wondering how anyone else does it. It degrades a detail if they still look nasty.
What works best on faded black plastic mirrors
Don't use PlastX, try Gold Class Trim Dressing and keep in mind the this type of material fades and turns ugly without maintenance, if you spruce them up but the owner of the car doesn't maintain them, they will turn ugly again.
They turned ugly the first time because they were not maintained, and it's likely the owner will not maintain them if they never did in the past.
Originally posted by foxhound58
Ok on GC trim dressing, will give that a try. Although I have used #40 let it soak while working on interior then buffed off with MF towel later, and looked better, but faded quickly.
How is the GC dressing different then #40?Never argue with an Idiot.. They'll only drag you down to their level, then beat you with experience..
I'm only guessing, but I think #40 is more for vinal & GC for plastic. There is another area in between the doors. It has a flat black finish. Don't know what that stuff is, but it's tough to make it look good again. Not positive, but think it may some kind of plastic covered or painted aluminum. It lookes like it is oxidized & nothing will help it either. Think I'll try the GC their also.
Thanks, Fox
Wont hurt to try... nothing in the Trim Detailer will damage anything. You might have an easier time applying the bottle version, if you can find it, and not the aerosol version of the trim detailer
Gold Class Trim Detailer
They turned ugly the first time because they were not maintained, and it's likely the owner will not maintain them if they never did in the past.I want 4" Softbuff pads!
It is a 97 chevy Z 71. They are almost like fiber glass. Was even considering the fiber glass boat stuff, before I found the forum.
Next one I get in, I think I'll try Mike's suggeston on the GC trim dressing. Live in a small town & you see it going down the road latter on, with those nasty looking mirrors, but everything else looking good is degrading to my detail.
Also same problem with the flat black material in between the windows on the door panel. Also GM product. Seen them also on olds, and pontiac models. I think this stuff is metal, and painted to look like or match the trim.
Thanks, Fox
GeorgeI want 4" Softbuff pads!
You know I did try #7 followed with #26 one time. That was my own vehicle though. Misted them with final inspection #34 after washing every time, which kept them looking good.
Maybe a different sealant would be good. Say #21 or #20. Would be better for customer that dosen't go to that extreme. They will just usally wash & at most towel it dry.
Thanks for the info, Fox
