Hey guys, is DC1 only for very very light swirls n such? I was thinking of maybe applying ScratchX first, and then DC1, but maybe that's a bit of an overkill? Is it? Also, do I have to work in DC1 like I have to work in ScratchX? And how long do I let it sit/apply?
#7 Show Car Glaze and Deep Crystal Step2 Pure Polish
You don't have to work in DC1 like you do ScratchX -- and if you have an orbital buffer, you can use that for DC1.
I would suggest using DC1 over the entire car. For any areas where there are swirls/scratches remaining, then use ScratchX just on those spots.
Doing ScratchX properly requires many applications and a lot of elbow grease -- and thus is really difficult to do for the entire car!
Originally posted by rudemood12
i just put on some #7 tonight for the first time and i did 3 passes in an attempt to remove it. this was, however, a recommendation by mr. phillips in an old autotopia post he had made - specifcally about applying/removing #7. i found it quite enlightening.
SL1CK,
IMO, DC1 couldn't remove my swirls, it's just to remove dust and dirt which washing couldn't remove, I DC1 the whole car, the swirls are still there, I would go for scratchX.
DC1 does/should NOT need to wait before removing, I wipe it off immediately, or else, you'll have ur biceps aching trying to remove it later.
fishbonezken- It's fine. Even if they've come out with a slightly different looking version and yours is a little old, it's still good to use. The #7 I have is the same color as yours. And I've used some *very* old #7 that worked fine.
And yeah, those are the only two pure polishes places stock in *my* area too. Too bad, they used to have all of them (I kinda like #5 myself due to its extreme ease-of-use). You might check autopaint/body supply shops, they can greatly expand your range of "OTC" products.Practical Perfectionist
We have a 2004 Saab 9-3 convertible. The finish was in pretty good shape. We had some mechanical problems with the car, and the dealer felt so bad about them that he threw in a professional detail for free. The car looked great for a few weeks, and then after I washed the car, the paint was full of swirls. There were a lot of them, but not that deep. DC1 removed over 90% of them . . . .
DC1 may remove some very light cobwebbing effect but its not going to be aggressive enough to get at bad swirlings.
DC1 made a small differnace on my black car but I still had some very light swirling.
I would honest;ly suggest finding a Porter Cable 7336 or a sander/buffer in the range on sale ( about $100 ) get a few 8006 pads, 1 9006 pad 1 7006 pad, a MF Bonnet pack and a 64-DA backing plate.
Pick up #83 #80 #7 NXT Liquid Wax
Start witha good wash, then a good Clay Barring of the car
Inspect the finish and decide how bad your scratches are. The really bad ones work out with ScratchX.
Now take the PC and the 8006 pad and some #80 and work a 12x12" area and see if you get rid of your scratchs / swirls. You will want to use about #15 of pressure on speed 5 and slow arm speed, then wipe off with a MD towel. Now reinspect and see if the did the trick. If it made a good sized dent try another round with the #80 and if that fixes it real nice then do the whole car like that. If the #80 didn't then get a new 8006 pad and do the same steps with #83
TO get a nice finish I would follow the 83 with 80, then #7 or DC#2 then NXT with the 9006 pad and remove with MF Bonnet on the 7006 pad.
I will never hand apply wax again, I can do 2 layers of NXT and remove with the MF Bonnet in the time I could lay down and remove about 3/4 of 1 layer.
Now once you have a good finish on the car you can maintain it with spray wax or going over it after a good washing with #7 first on a 8006 pad then the NXT wax as a follow up.
The initial bite hurts a little but the time and ease of use down the road is well worth the $$ up front.
-RobertMy Work log for my Magnum R/T Hemi Registry
heyya fish
ive been detailing for the past 2 years. megs are the only good OTC products here in malaysia, and u can only get them at very few places =)
ive used the DC 1 to 3 but later on added on few more to the system. i have a nighthawk black car so its more difficult to maintain.
DC1 is fine for a start. i am using #7 and it looks good on a black car. but you will need to apply in very thin layers if by hand. U can replace DC3 with the yellow tech wax or the NXT.
#7 gives you better gloss effect over the DC2
but, i have chosen the #20 polymer sealant and top up with a carnauba wax. with the weather here, using the DC 1 to 3 will not last you over 2 weeks, especially if it rains in between.
you can also use scratchX after DC1 if you have swirls.
cheers!
Originally posted by fishbonezken
Accumulator,
thanks for the tip!...maybe I should look for #3, the retail shops in my area are only selling Deep Crystal #2 and #7. That's what limiting my choice.
foxhound58,
lol, no wonder you needed 20 towels.
hey ivolusion,
thanks for the tips. yes the weather here really...S***ks...it's been raining for the past 6 days.
The product that i was looking for was actually ColorX, which is A M A Z I N G !!....beats DC1 flat!.
where do you buy your meg's stuff? I can't seem to find a place that sells most of their things, like from the Detailer line.
For the almost full range of products, get them from Hypercoat in USJ 1. Consumer line, professional line as well as the detailer line can be found there.
I'm planning to get additional stuff from the Detailer line as well.. Last Touch & All Purpose Cleaner.
