What is the best way to strip wax off a car?
Results 1 to 10 of 16
Thread: What is the best way to strip wax off a car?
    Registered Member RWayne's Avatar
    Oct 2005
    29
    16
    I was thinking about starting from scratch and am looking for a way to remove all previous layers of wax off my car and start fresh.
    From what I understand Clay barring a car will remove some wax.
    Is there any kind of car wash solution you can use that is highly effective in removing wax?
    What is the best way to remove wax off of a car with out hurting the paint?
    Is what I am trying to accomplish advisable?
    RW
    Sep 2004
    1,523
    32
    40
    19,238
    239
    I know what you are saying, but you actualy dont have to worry about it.
    Just wash the car with a quality wash solution, like Gold Class, etc.
    Then clay the car as usual. If any dirt is on/under the old wax, the clay will grab the wax and clay. If the old wax is completly smooth on the surface, it will get left behind, which is no problem.
    Following up with a paint cleaner like the DC#1 mentioned above will clean the paint, remove old wax, and remove swirls if a swirl-removing product is used.
    Then polish and wax as usual.
    Oct 2005
    29
    16
    The main reason I want to do this is two fold:
    1. I read an article on the law of dimishing returns where it said that the paint on a car could only hold so much wax. After that what ever you put on pretty much wipes off with each new application say like over 3 or 4 coats.
    2. I wanted to totally get rid of any previous layers of wax from non-meguiars products that I used before I learned about meguiars.
    By the way, I love your icon of the Bus.
    I am a Die Hard Steelers Fan also.
    Lets Pray that Big Ben's cycle accident does not affect his performance this year.
    RW
    40
    19,238
    239
    1. Sure seems that way. I use a spray wax after washing, but that just tends to give the 'fresh wax' look back, rather than adding full coats of wax.
    2. Between the clay and the paint cleaner, you will get anything old off.
    Ehh, Ben will be fine. Peyton Manning fractured his jaw a couple years back and missed one play. Hockey players break their jaws often enough. Nothing career ruining about it.
    Just have to figure out an icon for next season...
    Oct 2005
    29
    16
    How can you tell if you have wax on your car or not?
    A few months ago I noticed I had some bugs on the hood of my car so I washed it then used the paint cleaner and took a buffer and covered the whole surface of the hood. It rained the next day and the rain still beaded up on the hood of the car in very small beads. Therefore I saw it as evidence of wax. I was really impressed I was not expecting that. I did not even put a top coat of polish or nxt on it either. the sun was dropping quick so I never got a chance to finish the job from the day before.
    Isn't there any wax in paint cleaner at all?
    What is the difference between Megs deep crystal paint cleaner and their brand of cleaner wax? Isn't it the same thing?
    RW
    40
    19,238
    239
    It can be kind of tricky really. The best thing is when you get into using a wax regularly, you will notice when the slickness and look starts to go. One of the good ways is when the Spray Wax starts being tough to remove, your base coat of wax is getting thin.
    Beading isnt a great indicator of wax either. A completly clean surface will bead water as well, and some waxes dont bead water much.
    In the Deep Crystal Paint Cleaner, and ScratchX, there is no wax.
    The Deep Crystal is a paint cleaner only, and pretty good for being mild.
    The Cleaner/Wax is a mild cleaner, and also contains polish and a wax. It is probably a little milder of a cleaner than the DC #1.
    Oct 2005
    29
    16
    How did you know that? Where did you learn that from? I am not questioning your character. I was just curious.
    RW
    40
    19,238
    239
    Well, I'll assume you are asking about the water beading part...
    The simplest answer is that water will bead (stick to itself) when there is nothing else for it to stick to. Think of astronauts in space playing with liquids.
    So if your surface is completly clean, there is nothing more than paint for the water to stick to, and that wont make it spread out nearly as much as dirt would.
    Similarly, a well waxed car wont bead water well if it is dirty.
    Incidently, Mike has mentioned in the past that the ingrediants in wax that cause beading arent as good for the durability. And the ingrediants that give durability dont cause beading.
    Jun 2006
    15
    wash you car with a dish detergent aka Dawn... this will remove wax build-up
  1. Does QD Strip Off Wax?
    By CBLW in forum Meguiar's Consumer Line Products
    Last Post: Oct 31st, 2008, 06:46 AM
  2. Strip Wax, Clay, Polish, Wax??
    By basshog in forum Detailing 101
    Last Post: Oct 21st, 2006, 09:03 PM
  3. Will Quik Wax strip or break down old wax?
    By MikeP in forum Detailing 101
    Last Post: Aug 12th, 2006, 12:31 PM
  4. Strip wax
    By iplayazi in forum Detailing 101
    Last Post: May 20th, 2005, 04:55 PM
  5. Strip off last years' wax?
    By Qranc21 in forum Detailing 101
    Last Post: May 16th, 2005, 02:44 PM
