intended use for 3000 grit??
Results 1 to 10 of 13
Thread: intended use for 3000 grit??
    Guest for right now steveo3002's Avatar
    May 2005
    199
    0
    okay ive always used 1200 to de nib and take down any bad orange peel on new paint , then 1500 and 2000 to lessen the scratches and make polishing easier
    i just wondered whats the point in 2500 and 3000? is it simply to lessen the scratches from the more abbrasive papers or does it have a use other than wet sanding new paint
    i cant imagine 3000 would have enough bite to remove defects like bird mess etchings etc
    what would polish would take care of 3000 grit?
    38
    19,079
    235
    It is just to leave finer sanding marks, so that a person could potentialy remove them by PC even, or maybe even ScratchX.
    Leaving marks that are too heavy would require a rotary, and that isnt for everyone.
    May 2005
    199
    0
    ok thought as much
    anyone know what removes the most paint?
    polishing up 1500 marks with suitable polish or sanding those 1500 marks with 2000-2500-3000 and then polishing with whatever is suitable?
    Nov 2004
    SoCal
    2,304
    41
    I think it really comes down to technique.
    In theory, whether you go through twelve steps of sandpaper or one round of compound, as long as you just work until you hit the bottom of the deepest original defect you remove exactly the same amount of paint either way. In practice I think it's going to differ based on how you handle the paper vs. how you handle the buffer.
    You can grind all the way through a finish with either.
    I find sanding easier to control than a rotary buffer (maybe cuz I'm not all that good with a rotary yet) but I sure wouldn't say I'd remove less material when sanding.
    PC.
    Registered Member sneek's Avatar
    Aug 2005
    2,736
    41
    hehe i wet sanded a mobility scooter to remove orange peel with 2000 grit and removed the sanding marks with ScratchX but the paint was pretty soft single stage
    Professional Detailer Jimmy Buffit's Avatar
    Indianapolis, IN (Carmel)
    290
    18
    We finish with 4000... polish with rotary and #83, and finally PC/#80.
    Oh, that's nice...
    Jim
    www.jimmybuffit.com
    May 2005
    199
    0
    wow 4000 must polish easy....i have in the past polished up 1200 scratches
    Nov 2005
    210
    16
    I recently wet sanding on a scrap panel where I used 2000 grit and I was able to buff that out with a #83/W8006 combo with my rotary buffer.
    I would think that you would need at least #84 to accomplish this.
    Aug 2005
    2,736
    41
    did you use unigrit papers or 3M papers, the reason I ask is that I find that the unitgrits buff out better. dont get me wrong the 3m stuff still buffs out but the looks like theres slight micro marring
    Nov 2005
    210
    16
    I used 3M paper since this is what I had lying around. I did notice some slight micro marring, however keep in mind that #83 is not usually what should be used to buff out wet sanding scratches. From my understanding #84 is what should be used for this task. The next time I order some Meguiar's products I will order a few sheets of the UniGrit paper and give it a try.
  1. Polishing After 3000 Grit Sanding
    By JJ1 in forum Detailing 101
    Last Post: Feb 15th, 2008, 08:27 AM
  2. Using DA w/ products intended for hand application
    By Scout and me in forum Detailing 101
    Last Post: Dec 15th, 2007, 09:17 AM
  3. Have you ever used a product not intended for car care?
    By electricgreen in forum The Break Room
    Last Post: Oct 4th, 2006, 09:21 AM
  4. Almost 3000!
    By Mike Phillips in forum The Break Room
    Last Post: Jun 28th, 2005, 08:21 PM
  5. 3000 grit... use #83?
    By integraoligist in forum Detailing 101
    Last Post: Jun 3rd, 2005, 11:08 AM
