#83 with a Light Cutting or Polishing Pad???
Results 1 to 4 of 4
Thread: #83 with a Light Cutting or Polishing Pad???
    Detailer for Hire GTBrad's Avatar
    Jun 2006
    36
    178
    14
    So I still haven't purchased some W8006s
    So for now, I'm trying to work with these LC pads
    I'm applying #83 to my 2001 Ford Mustang using LCs light cutting pad, possibly the equivalent to the maroon W7006. I understand that this is quite an aggressive combo, however I am still showing a good amount of swirling.
    I'm using only a small bead of product around the edge of the pad, working it in at a slow arm speed with a PC speed setting of 5, and I'm using the correct pressure on the head of the polisher. I let the product work in for about 5 minutes making roughly 4-5 passes
    My results are and slight haze from the cutting pad, that's easily fixable with the #80, but the swirling is still showing.
    What could I be doing wrong?
    Overapplication?
    Not letting the diminishing abrasives break down?
    How hard is ford clear coat?
    -Brad
    Shine Masters Pasadena, CA
    shine-masters.com
    57
    24,767
    518
    Re: #83 with a Light Cutting or Polishing Pad???
    Overapplication?
    Hi GTBrad,
    Why don't you make plans to come to this weeks Meguiar's Garage, bring your LC pads and let us have a stab at isolating the problems and showing your the solutions.
    I'll create the sign-up thread right now.
    Jun 2006
    36
    178
    14
    THANKS MIKE
    Sounds good, I'll see if I can make it out there!
    -Brad
    shine-masters.com
    Registered Member sneek's Avatar
    Aug 2005
    2,736
    41
    #83 does dust with the orange pad. it doesn't dust with a W8006, I have no idea why but i know it as a fact. I was using a new orange pad and #83 on a cool surface and it started dusting almost right away.
  1. Cutting Pad
    By jezroj in forum Machines - The Dual Action Polisher
    Last Post: Aug 24th, 2008, 02:30 PM
  2. Cutting Pad?
    By Rowen in forum Detailing 101
    Last Post: May 10th, 2006, 05:59 AM
  3. Cutting Pad V Wool Pad
    By Tanat198 in forum Detailing 101
    Last Post: Mar 7th, 2006, 08:40 PM
  4. Cutting Pad vs Polishing Pad & DA
    By Question Boy in forum Detailing 101
    Last Post: Apr 10th, 2005, 01:38 PM
  5. First time using the cutting&polishing pad
    Last Post: Dec 21st, 2004, 06:04 AM
