As I polish my car using DCS #2 and found that it cant remove tar with it even i try very hard with lots of polish on my cloths, its just cant works. what other product could make this job easy ? Also I founf the DCS is unable to romove swirl marks and fine hairline scretches on surfaces as its stated on the label. I want my car finishes like pro , what pro product I need to use to remove minor swirl mark and hair line scretches ?
How to remove tar easily?
You could try GC Bug and Tar Remover. I used to use Extra (which has been discontinued), but this is supposed to work well for... well, bugs and tar.
- Ben
Hi Vincent
I first wash down the area then use Meg's bug and tar remover. I spray it on, let it sit a few minutes, then use a terry cloth to agitate. Depending on how long it's been sitting on the car you may have to do a couple applications to get it off.
Here is a picture of it in action. Left side you can see the tar breaking down, right side just wiped off with a terry
Re: How to remove tar easily?
Hi Spotty,
Thank you so much for your tips and photo. I will try it as yous advise and let you know the results. Now I knew DCS #1,2,3 doesn't work very on tar and scretches..Is not how you shine your car, Is what you shine your car with
Hi Spotty,
