Never wet sanded before
Results 1 to 2 of 2
Thread: Never wet sanded before
    Sep 2006
    My car got keyed last year.I touched up the paint already.There is a little more touch up paint on the car then I want.My question is how do I wet sand?And doesn't sanding the paint hurt the finish of the car?
    Registered Member Chex's Avatar
    Mar 2005
    33
    268
    16
    Re: Never wet sanded before
    Wet sanding does not hurt the paint finish, but it do is the most aggressive method to remove defects. so it will hurt the finish if your skills are not well-trained yet. however, ir you're confidnent, and you've never don it before, go ahead. I started like that. Just a few tips to do this:
    * do it with a 2500 to 3000(recommended) grit sanding paper. Meguiars has these available
    ** buy a foam sanding backing pad (Megs or 3M, whichever you can get)
    ** soak the papers at least 15 minutes before starting on water with some car wash shampoo added.
    ** put the sandpaper in the backing pad. be sure the sanding paper surface you'll use Doesn't fold or you could instill deeper scratches :P
    ** work in straight line motions. do 7 to 10 passes and check your work. also be sure to use light to meduim pressure to keep yourself in the safe way.
    and after working, be sure you're familiar with the use of a rotary and a compound.
    I could tell you to use a 2000 grit paper or higher (1500,1200,1000), but it's better do do this slowly but safer, than faster and with more risk.
    Hope this helps
  1. Replies: 15
    Last Post: Nov 13th, 2008, 10:48 PM
  2. Is clearcoat usually replaced if wet sanded?
    By kzyman13 in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Sep 3rd, 2008, 08:29 AM
  3. Pic of my wet look**
    By Premier Auto Spa in forum Show Off Your Latest Detail Work
    Last Post: Mar 23rd, 2007, 06:39 AM
  4. LA Auto Show - good wet sanded cars.
    By corky5678 in forum Car Shows & Industry Events
    Last Post: Dec 14th, 2006, 06:00 AM
