Can I realistically get near-professional results with Meguiar's Consumer Products
Results 1 to 8 of 8
Thread: Can I realistically get near-professional results with Meguiar's Consumer Products
    Oct 2006
    3
    15
    New to this forum - first post.
    I recently bought a black '97 Mazda Miata. The paint appears to be in good shape (high gloss) but in direct sun it has alot of swirl marks (similar to the 'before' photos of 'Superior Shine''s photos of the NGX in the Extreme Makeover forum.
    So I went out and bought the Meguiar's Deep Crystal System. I washed the car with the Car Wash, then wiped dry with microfiber cloth. I then applied the Paint Cleaner (with a terry applicator pad) and - Whoa! I got a very streaky look - like fine scratches in the same direction (front to back) that I applied.
    After reading many posts in this forum, it seems I should try a foam applicator pad - but am I wasting time here? Can I realistically expect to get close to the 'after' photos of the NGX or should I just pony up the bucks to have this done professionally?
    On Vacation
    Jul 2004
    New Jersey
    565
    23
    Re: can I realistically get near-professional results with the consumer products
    Well, first of all, it's very difficult to remove swirls by hand, generally speaking. How does the paint feel after washing? Is it rough or smooth? If it's very rough, you may have some contaminants that were broken loose with the DC1 that you are dragging around on the surface, or maybe a dirty/rough terry applicator.
    Detailing BoZo jfelbab's Avatar
    Apr 2004
    Cape Coral, FL
    1,485
    33
    Welcome to the forum, consumer.
    It's very difficult but not impossible to remove swirls by hand. You might give it a go with ColorX or ScratchX and do a 1' x 1' square at a time until the surface is as you want it. If you can I'd highly suggest buying a Porter Cable polisher. Meguiar's G100 with it's lifetime guarantee or the PC 7424 or 7336. This tool makes polishing 10 times faster and easier.
    Before polishing though Wash, and clay the vehicle. Then polish and wax.
    Yes, you can achieve excellent results with consumer products. It just takes a bit more work.
    41
    19,269
    239
    Oct 2006
    3
    15
    thanks all for the advice. I read through the article on removing swirls by hand - is ScratchX more or less agressive than the DC Paint Cleaner? My thi niking is if ScratchX is more agressive - then I dont't think I want to use this?
    41
    19,269
    239
    ScratchX is more aggressive than DC#1, but both are on the very mild scale. If you feel ScratchX in your hand, it feels like a hand cream.. very mild.
    Now, both products are for different purposes.
    ScratchX is for removing light swirls and scratches by hand. It is a product that takes a lot of effort to work in, and really ***** if you have to do a whole car.
    DC#1 is a mild cleaner, that is meant for regular use on the car, and while still should be worked in a little, is meant to be used more quickly overall.
    Registered Member Power Stroke Diesel's Avatar
    Oct 2006
    15
    Quote Originally Posted by consumer View Post
    So I went out and bought the Meguiars DeepCrystal System. I washed the car with the Car Wash, then wiped dry with micofiber cloth. I then applied the Paint Cleaner (with a terry applicator pad) and - Whoa! I got a very streaky look - like fine scratches in the same direction (front to back) that I applied. After reading many posts in this forum, it seems I should try a foam applicator pad - but am I wasting time here? Can I realistically expect to get close to the 'after' photos of the NGX or should I just pony up the bucks to have this done professionally?
    The short answer Yes! and Maybe:
    First of all put the terry applicators in the round file they are worthless and will cause streaking. Use the foam applicators and remove the product with either a deep nap terry cloth soft towel or a mirofiber towel. Scratches can only really be completely removed by use of a rotory buffer (not recommended unless you know what you are doing). Some products will do a good job of hiding the scratches but over time they will come back. If you want the car to look great you are on the right track. If you want it to be flawless have it wet sanded flat buffed and never drive it, which would be a shame.
    Registered Member matt_c's Avatar
    Sep 2006
    53
    16
    The money you spend on buying a G-100 will be worth it many times over if you want to have and keep a showcar shine. Its worth it, just to not have to do all that arm work trying to polish by hand.
    2006 Jeep Wrangler X
  1. Looking for professional detailer who uses Meguiar's products near Tarzana, CA
    By cartracr in forum Auto Detailing Company who uses Meguiar's Wanted
    Last Post: Jan 29th, 2009, 09:24 AM
  2. Replies: 8
    Last Post: Nov 2nd, 2008, 08:25 PM
  3. Professional and consumer products
    By sstruck in forum Meguiar's Retail/Consumer Line Products
    Last Post: Dec 29th, 2007, 09:13 PM
  4. consumer vs professional
    By jon008 in forum Detailing 101
    Last Post: Jan 26th, 2007, 12:53 PM
  5. Consumer vs. Professional Products?
    By mharris672 in forum Customer Service Hotline
    Last Post: Jun 5th, 2006, 12:57 AM
