White fiberglass gel coat polishing and restoring gloss
  • White fiberglass gel coat polishing and restoring gloss
    Hi from Northern Ontario, Canada. Yes, we do have snow already on the ground. Got a job for me in Arizona, Texas, or even New Mexico ? I need to warm up.
    But to the real reason I am here.
    I have a 2002 Chevy 1-Ton Aerocell Van. It is basically a "bubble van" made of fiberglass by Del Truck Bodies. The gel coat is dull dreary and in need of a great restoration to new.
    I have looked at liquid glass for boat gelcoat: looked at the poly coating to restore the gloss: BUT I got the brainwave to contact my friends at the Meguire's Car Crazy Forum to see if anyone out there has found a great Meguire's solution to my problem.
    Anyone care to comment?
    You can e-mail me at baypressure@on.aibn.com if you have suggestions.
    Direct comments to Bill.
    Thanks a bunch fellow Car Nuts.
    Re: White fiberglass gel coat polishing and restoring gloss
    Try to find the Mirror Glaze Fiberglass Oxidation Removal System (M 4965) It has # 49 Oxidation remover, # 45 Boat & RV polish and #56 Boat & RV wax in it. I have used it to resore some pretty ugly boat finishes before.
    Good luck.
