Solo Pad System
TECHNICAL BULLETIN
Uniquely engineered wool and foam buffing pads designed to effectively work with Cut & Polish Cream (M86) for professional’s who demand a simple approach to world class swirl-free results
Part #:
Wool Heavy Cutting Pad – WWHC7
Diamond Foam Polishing Pad – WDFP7
Wool Light Cutting Pad – WWLC7
Diamond Foam Finishing Pad – WDFF7
Packaging: 1 Pad, 6 per case
Features:
Wool Heavy Cutting Pad - 7”
• 100% wool, 1” twisted fiber for faster cutting
• Effective removal of sanding marks and defects
• Color coded buffing pad, burgundy for “heavy cutting”
• Flat pad design expands cutting area to reduce buffing time
Wool Light Cutting Pad - 7”
• Unique 1” blend for less aggressive, safer cutting
• Color coded buffing pad, yellow for “light cutting”
Diamond Foam Polishing Pad - 7”
• Soft foam technology removes moderate swirls and holograms
• Delivers revolutionary, swirl free performance
• Smoother buffing action” less chatter” with diamond pattern foam
Diamond Foam Finishing Pad - 7”
• Ultra-soft foam technology removes light swirls and holograms
Application Method:
Foam Pads - D.A. Polisher, Rotary Buffer
Wool Pads - Rotary Buffer
Directions: Choose appropriate pad for desired results. Mist dry pad with M34 Final Inspection to prime pad prior to buffing. Keep the buffing pad flat to the surface to minimize swirl marks. Clean pads frequently using appropriate tools (Foam – nylon brush or cotton towel. Wool – wool spur). Store pads in re-sealable bag while not in use.
TECHNICAL BULLETIN
Part #:
Features:
Application Method:
FOR ADDITIONAL SAFETY INFORMATION, CONSULT MSDS. KEEP OUT OF REACH OF CHILDREN
Meguiar’s® Help Line 800-347-5700 www.meguiars.com (10/06) VMGTB-SoloPads
