Please advise if my 'wetsanding' technique is correct?(with pictures)
Results 1 to 10 of 12
Thread: Please advise if my 'wetsanding' technique is correct?(with pictures)
    Registered Member fishbonezken's Avatar
    Jun 2006
    227
    23
    Hi all,
    I recently worked on an older model Honda Civic, and there was this scuff mark on the door, which I tried to remove with ColorX. It removed only very little and it took too much elbow grease.
    So I tried using M80 by hand, removed faster, but the scuff mark was too thick. It would take too long.
    Then I decided to try 'wetsanding'. I have no experience what so ever, and I didn't know that I was suppose to soak the sandpaper in water prior to use.
    I took a generic 1500 grit sand paper, cut it into a small rectangle and sprayed on soapy water onto the scuff mark and onto the paper.
    Then I sanded carefully and [/B]lightly[B]. To my horror, I saw sanding marks, the paint appearred to be chalky, I was terrified. OMG I spoiled the paint, and it is not my car!
    I tried to remove with colorX by hand, it faded just a little, and then i tried M80 by hand with a terry towel, the sanding mark dissappeared! So I got confident and tackled other spots like this one.
    Before
    During
    After
    I sanded like this, should I use a sanding block? The scuff mark was very thin, so I tried to sand the area itself and not too much paint around it.
    And this is the result after :
    a generic 1500 grit sandpaper
    M80
    terry towel
    Soapy water
    lots of elbow grease
    Am I doing anything wrong?
    All comments/critiques/advice would be greatly appreciated. Thank You!
    59
    24,767
    519
    Re: Please advise if my 'wetsanding' technique is correct?(with pictures)
    Actually, it looks like you're process is working. Here's one thing you might want to do and that's inspect your results in different lighting conditions because sometimes it can be hard to see surface imperfections, (like leftover sanding marks), unless you're in the right light.
    Removing sanding marks by hand must be very challenging, of course this depends upon how hard or soft the paint is; usually people use a rotary buffer and a compound to remove sanding marks and typically M80 Speed Glaze by hand will not be effective enough to count on as a sure-fire process.
    Avatar Czar BlueZero's Avatar
    Aug 2006
    Green Bay, WI
    3,314
    49
    The before and after shots look great. I'd say you did something right.
    I'm not a wet-sanding pro. I've only done it twice. But one thing I learned is if your going to use 1500 grit, follow up with 2500 grit. It's allot easier to get out the sanding marks.
    This was my first try...
    http://meguiarsonline.com/forums/showthread.php?t=16536
    Scott
    Jun 2006
    227
    23
    Thanks Mike!
    I'll try to look at it with different lighting conditions. The pictures only okay under normal light. Maybe there were more marks left if it is looked under a 500w halogen lamp? thanks for the tip.
    Jun 2006
    227
    23
    Quote Originally Posted by BlueZero View Post
    oh yes, I'll have to get me a sheet of 2500 grit sandpaper. Your first try was quite successful too.
    Btw, did you notice that the water around the sanded area becomes a little bit whitish?
    I've read that this is the clearcoat being washed away.
    would you happen to know that if this is normal?
    Aug 2006
    Green Bay, WI
    3,314
    49
    Quote Originally Posted by fishbonezken View Post
    Mine did the same thing. Left a spot on the nice new garage floor too. I would think it's normal because that's what you want to do is remove some of the clear coat. I get a sick feeling while I'm doing it, worrying about taking off all the clear. I don't think I'll do anymore wet-sanding until I get a junk body panel to practice on.
    Scott
    I am the paint whisperer. Superior Shine's Avatar
    Feb 2004
    Covina / Los Angeles
    4,734
    207
    You can't argue with good results but I see a few things I would do different.
    First, the paint transfer could have been removed with mineral spirits or simiular solvent.
    Keep some abrasive cleaners on hand (#85) for just that type of thing that solvent is too much over kill for.
    Also, sanding like that will get you in trouble one day. Use a block when possible.
    Again nice work.
    Registered Member sneek's Avatar
    Aug 2005
    2,736
    42
    Couldn't you remove that paint transfer by using clay followed by DC1?
    Jun 2006
    227
    23
    I feel the same too. yes a junk body panel is good for practise.
    Then we can see how easily we can sand through the clear.
    Jun 2006
    227
    23
    Quote Originally Posted by Superior Shine View Post
    Again nice work.
    Thank You Joe !
    I did not know that mineral spirits could remove the paint transfer, will it be harmful to the car's paint that it's being worked on?
    Yes, I'll use a block next time.
    Thanks again.
  1. Wetsanding
    By Booby in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Dec 27th, 2006, 12:41 AM
  2. How is my wetsanding? with pictures !!
    By duy_k2000 in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Dec 13th, 2006, 04:53 PM
  3. Wetsanding/Touchup Help
    By clark_carty in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Aug 27th, 2006, 06:56 AM
  4. Wetsanding
    By fordfan in forum Detailing 101
    Last Post: Dec 7th, 2005, 08:33 AM
  5. wetsanding marks
    By Heynen in forum Detailing 101
    Last Post: Sep 25th, 2004, 04:44 AM
