I have a big 27 ft. boat and two jet skies to practice on. I have never done a boat before. What do I need? What do I do? How long will it take me?
New to boats
Re: New to boats
Just like a car's finish you'll want to evaluate the condition of the surfaces you're working on and then let the condition of these surfaces be you guide to help you choose the right products.
Try to find out if you're working on Fiberglas gel-coat or if the boat or Jet ski's have been painted. Gel-coat is typically thicker than paint so you'll have some film build to work with, paint on the other hand is usually thin and this means no room for mistakes.
If the boat is in pretty decent shape you might want to consider using a one-step Cleaner/Wax because going around a 27' boat in one step and getting great results will be a real time saver versus going around a boat using a multiple-step process which if you consider just the wipe off of products it's enough to make you tired.
Re: New to boats
Both the boat and jet skies have gel coats. They are older (late 80's) but in good shape for their age. Of course they are oxidized, enough that there is no shine at least. The boat has vinyl that is in good shape. The owner has gotten really great results before with what I think is a DA, but he say's it's doesn't last very long. Currently I only have my hands and an old orbital buffer to work with, but I am pretty sure I can get a machine by then. The boat is white, the skies are yellow. The leather seat on one of the jet skies has a horrible stain/burn? I don't know if that can be helped. Any help would be appriciatedDanny Jensen, Detail Lab
Re: New to boats
Originally posted by Detaillab View Postanybody?
Re: New to boats
Originally posted by Detaillab View PostBoth the boat and jet skies have gel coats. They are older (late 80's) but in good shape for their age. Of course they are oxidized, enough that there is no shine at least.
You might want to look at this kit that has an oxidation remover, a pure polish and a pure wax, this would be everything you would need to remove the oxidation, restore the gloss and protect the finish when you're done.
Fiberglass Restoration System
You should be able to pick this up at an Marine supply store or you can order it online.
Re: New to boats
Originally posted by Detaillab View PostThat was what I was thinking, can it be done by hand? if not I will need some instruction becuase I have never used anything but an old orbital
A 27' boat is going to be a lot of work by hand, purchase a dual action polisher and charge enough money to recoup you investment and then some.
Re: New to boats
Originally posted by Mike Phillips View PostYes, these products can be applied by hand.
A 27' boat is going to be a lot of work by hand, purchase a dual action polisher and charge enough money to recoup you investment and then some."Now go home and get your shine box"
Billy Batts in Goodfellas
