Hi, i just recently bought a used fender from a junkyard for my Grand Cherokee, the fender colors match and all but the pinstripe does not match mine. How do i removed the pinstripe paint another one? the pinstripe is not a sticker type, more like paint on pinstripe, but i can feel it on the fender when i run my hands over it. the question is how to remove that pinstripe without hurting the rest of the fender (cringe teeth) or i was thinking about painting over it it but the lines are not really in line with the rest of the car, slightly off.
how to remove pinstripe on fender
Re: how to remove pinstripe on fender
I've got good news and I've got bad news, assuming we're talking an earlier model ZJ Grand (93-98... I'm less familiar with the WJ-style bodies).
The good news is that it's stripe tape -- a sticker -- and in theory could be peeled off.
The bad news is that from the factory, the stripe tape is applied before clearcoating, and is under your clear. So there's no way to remove it without doing a respray of the entire panel.
That said, a few vehicles escaped the factory with the stripe tape above the paint, in which case you can peel it off easily. If your fender isn't from one of them, it's paintin' time.
Originally posted by hkpohah View PostHi, i just recently bought a used fender from a junkyard for my Grand Cherokee, the fender colors match and all but the pinstripe does not match mine. How do i removed the pinstripe paint another one? the pinstripe is not a sticker type, more like paint on pinstripe, but i can feel it on the fender when i run my hands over it. the question is how to remove that pinstripe without hurting the rest of the fender (cringe teeth) or i was thinking about painting over it it but the lines are not really in line with the rest of the car, slightly off.
Plastic razor blade? Then remove any scratches from the plastic razor blade after the fact.
One of our forum members recently did this, it took hours and hours.
Originally posted by hkpohah View Postthe pinstripe is not a sticker type, more like paint on pinstripe, but i can feel it on the fender when i run my hands over it.
In the case of a painted on pin stripe, if it's factory and it's on top of the clear then it's possible for a very talented person to carefully sand it off and then carefully remove their sanding marks, but the risk of burning any high points such as a fender line exist if the pin strip is next to such a high point. Definitely not the way to learn how to wet-sand and use a rotary buffer.
If the pinstripe is aftermarket paint, it's possible you could rub it off with something like ScratchX with a little passion behind the pad, depends on the type of paint used. You could always try to see what you can do.
