I am a newbie to Meguirars products and a friend helped me do some detailing work on my new 2007 Toyota Highlander.
I applied some NXT wax by hand then then removed the wax using his Porter Cable polisher with a foam pad and bonnet over the foam pad. I do not recall a speed setting on his Porter Cable unit I simply turned it on and remove my NXT was and it worked great.
I was so impress I ordered a bunch of products from ADS including a G100A with a W8006 foam pad and I plan on using the Meguiars Super Plush Thick Microfiber DA Polisher Bonnets to remove my NXT paste wax.
I did locate the chart of suggested speeds based on pad type etc. and it suggest a speed of 2-4 for that foam pad type but doesn't talk about using a Microfiber Polisher Bonnet.
So here are my questions
1) Where is the G100A speed selector located on the polisher ?
2) Does the PC model not have this feature ?
3) Since I am going to be using a Microfiber Bonnet over the top of the W8006 to remove my NXT paste wax does the suggested speed setting of 2-4 still apply ?
Sorry if this post is a repeat but I did some searching and couldn't locate much information on how to set the speeds on the G100A and I could not locate a users guide or online manual for the G100A.
Plus my G100A has not arrived at my house yet but I like to research things a bunch before I attempt to do them myself for the first time.
Thanks a bunch
Thanks a bunch
