Hello all, this is my first post on the board.. seems very informative and helpful.
Ok here's my problem, I tryed using Meguiars #83 on the porter cable 7424. The instructions on the bottle said to work until dry... I was having to buff off alot of material, a friend of mind says you shouldn't have to the product should be like dust when you've worked it in enough. I know I did something wrong because I didn't get any result really, the vehicle is a 2003 Mach 1 that has quite a bit of swirling/ marring.. I bought the vehicle in the winter ( was my only car at time) so I had to take it through the car was a few times. Unfortunatley It swirled my paint good and I'm trying to get rid of em'.
a little more information I started with the speed at 3 then cranked up to 4-4.5 I was using a yellow meguiars pad. Didn't work out to well, all the swirls are still there. any advice?
