I just picked up a set of 3 piece wheels which have an anodized lip. They are in decent shape, but could use a little work. I plan to clean them up first with soap and water, followed by an few applications of the multipiece wheel cleaner to clean up the back of the wheel. This is where I'm unsure of where to proceed. There seems to be some embedded dirt in the surface, which I would like to treat with a claybar. Is it safe to claybar an anodized wheel? Following the claybar, is there a cleaner/polish such as DC1 or scratch-x that can be used on the anodized lip to remove any residue/oxidation on the surface of the anodized lip? Once they are prepped, I plan to give them a coat of M21 for protection from further damage, but I just want to bring back the finish as best as I can without damaging the finish. Any help would be appreciated
Restoring Anodized wheels
Re: Restoring Anodized wheels
I have a set of anodized Fuchs rims. I've read a little about them, but I'm not sure about some things.
First, the anodized coating is very porious and a lot of grime will get permanently stuck on them.
Second, I would not use any cleaner on these wheels just to be on the safe side and protect your investment.
Third, I'm almost positive that claying these rims would be fine. I have never had an instance where clay actually hurt anything! I would be shocked if it did because clay is so gentle.
As for coatings, I would not suggest that you use a cleaner wax, although it probably would be ok. I do know for a fact that #21, #20, NXT, #26, #16, and GC Wax will be perfectly safe to use on any wheel. #21 is preferred, however because of its ability to last longer and resist dirt and help protect.Chris
Dasher Detailing Services
You can clay and wax the anodized wheel, but other than that there's not much you can do to restore an anodized surface.
Sorry didn't get back to you sooner, we were teaching a class on Saturday, (when you posted your question), and we try to take Sunday off to spend time with our family.
Originally posted by Mike Phillips View PostYou can clay and wax the anodized wheel, but other than that there's not much you can do to restore an anodized surface.
Originally posted by hai4ap View PostThanks for the reply. So that means a no on the DC1 or scratch-X? Wouldn't DC-1 provide a better surface for the M21 to bond to or is that not the case on amortization?
You could always to a test spot on one wheel, or just do one wheel and then watch the visual appearance of the wheel for the next month and see if you can see any difference.
