I'm polishing with Swirl Remover 2.0 #9 and sealing with Synthetic Sealant #21 a black car. I've done everything but the front bumper with has thousands of pin sized road chips. Any thoughts of using TurtleWax Color Magic on just that area? I've used it on light scratches with good results but not a whole panel. Should I use #9 first, then the Turtle and finally #21? Or should I just use the Turtle buy itself?
Any thoughts on colored waxes?
Re: Any thoughts on colored waxes?
I have never used a color wax but doing some reading on this product, sounds like its only going to fill the swirls and scratches and the results may not last long.
Turtle Wax Color Magic is an advanced blend of polish, dyes and pigments fill in light scratches and swirl marks.
Are you trying to remove/hide the rock chips? If so the only and best solution to fix the problem area would be a repaint. But if you have the TW already its not going to hurt to give it a try.
Here is a good post: Colored Waxes - Do they really work?Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
Originally posted by gr8-wrx View PostIn my experience (from a few years ago), the colored wax will wash off the next time your wash your car. This occured when using the either the colored wax or colored "lipstick" that came with the wax.
