I was just given a gallon of Speed Glaze. This appears to be old stock, at first I thought this product to be the same as #80. I was reading and comparing the directions to determine if this to be true or not. The directions mention once applied it should be allowed to dry to a haze then wiped off. I also noted that the directions do not mention the use with a DA. So my question is, is this product the same as 80 and can it be used with a DA ? If not then what situation would it be used ?
Thanks in Advance
--Dan--
Thanks in Advance
--Dan--
