Will #83 be enough to fix scuffs?
Results 1 to 4 of 4
Thread: Will #83 be enough to fix scuffs?
    Mar 2006
    42
    15
    16
    I picked up a new 99 Eclipse GSX project. I don't think I've ever seen a car with this many scratches before. Would #83 be enough to save this or will I have to step things up a bit or ... even get a new clearcoat?
    Fender:
    The rest of the car looks like this:
    The worst of it is this:
    Boost Addict dietoremain's Avatar
    Dec 2006
    Riverside, Ca
    34
    298
    17
    Re: Will #83 be enough to fix scuffs?
    I've removed scuffs like that from my grandmas maxima with just using #80 and a bit of #83 on one part. So it just depends on the paint hardness. can you feel the scratches? if not there is definitely a chance you can remove them.
    Registered Member TrufflePig's Avatar
    Apr 2006
    1,246
    28
    Test Spot!!!
    Registered Member jarred767's Avatar
    Jan 2007
    Bend, OR
    37
    687
    21
    It definitely depends on the hardness of the paint. I just did a black lexus yesterday that had scratches and swirls all over the place. Even had some pretty bad scuffs on the left rear bumper. I used 80 over the whole car with a DA, but first used 83 on the scuffs and major scratch area, came out looking amazing. Just make sure that when using 80 you really put some effort behind it. Go slow, overlap 50% and make sure to add pressure, and you should get really good results. 80 and 83 are both amazing products and if used correctly should give you a great result.
    Dynamic Detailing
    541.668.0480
  1. Scuffs, and how to remove them?
    By Taipans in forum Detailing 101
    Last Post: Sep 2nd, 2008, 05:58 AM
  2. Magic Foam Eraser is Amazing on Scuffs!!
    By audioguy99 in forum Interior Care
    Last Post: Apr 23rd, 2007, 10:58 AM
  3. How to fix this?
    By douglash in forum Detailing 101
    Last Post: Dec 17th, 2006, 01:49 PM
  4. How would u fix this...?
    By xal951 in forum Detailing 101
    Last Post: Jan 24th, 2006, 12:01 PM
  5. Spots on rearview, light scuffs on trim, help!
    By TexDetailer in forum Detailing 101
    Last Post: Jul 8th, 2005, 12:36 PM
