waxing by hand
Results 1 to 10 of 14
Thread: waxing by hand
    Registered Member d.mopar's Avatar
    Feb 2007
    30
    172
    16
    waxing by hand
    if u have already viewed my zymol thread in the break room, this is something to look at and it probably 1 of the things i find interesting. they use a hard carnuba block thing and take a piece of it in there hand so it melts and then with ur hands u rub it onto the car.
    - INKO'S
    ~ What White Tea Taste Like
    Registered Member onnfire's Avatar
    Jun 2006
    259
    18
    Re: waxing by hand
    Their claim is that the heat of your hand melts it and makes it go on. However, now that i own a pc, that would seem like a major pain. And you probably cant get as thing of a layer of wax with your hand as you can with the pc.
    '00 Audi A4 1.8 T
    '09 Audi A4 2.0 T Quattro
    Attention to detail is the key to success
    Steve
    Feb 2007
    30
    172
    16
    Re: waxing by hand
    yes but with ur hands its seems to be much fancy like maybe it works better that way. i mean melting ur carnuba with ur hands to lather ur car. thats just crazy.
    - INKO'S
    60
    24,761
    520
    Re: waxing by hand
    It's a marketing strategy about creating the perception of;
    • Unique
    • Special
    • Exclusive
    • Reserved
    • Aristocratic
    • Fill in the blank
    Back in about 1991 I actually waxed a car that I had buffed out first by machine, (rotary buffer), and then bare-hand applied two coats of M26 Liquid wax. That is I used my bare hand to apply the wax. I mostly did this to see what it was like, to see if there were any benefit to using your bare hand to apply a wax to the paint on a car.
    In my opinion, for whatever that is worth... there was no benefit at all..
    At least no benefit that made it better than using a normal, foam hand wax applicator pad or a foam buffing pad on a machine. I have never used my bare hand to apply a wax to a car since then and I've worked on a lot of cars. A foam wax applicator pad can absorb, in this case absorb some wax, (or a paint sealant), and then when you press on the foam just a little it will release some product enabling you to spread it out. You skin can't absorb and hold a little wax, (or paint sealant), like a quality foam applicator pad and so pressing on your skin, or pressing your skin against the paint won't release any wax or paint sealant, you have to go back to the source and get some more wax or paint sealant back onto your hand to continue spreading product.
    There was one tiny benefit to applying wax with a bare hand and that was using your sense of touch if you sensed or felt any kind of particle between your hand and the paint you could stop and remove the offending particle. Not sure I've ever seen this pointed out by any other forum personality that practices bare-hand waxing? With an applicator pad you can't feel tiny particles, you have to turn your applicator pad over often and visually inspect for them and this by the way is a good habit to forum or "Best Practice" when applying any paint care product by hand or machine.
    In a perfect world, the best way to apply a wax or a paint sealant to paint is without a doubt by machine, specifically a dual action polisher with a soft finishing pad or a polishing pad on the 3-4 speed setting after the paint has been previously cleaned and polished.
    Spreading the pressure out
    Bare Hand
    When you're working with your bare hand, there's no interface to spread pressure out, just your hand against the paint.
    DA Polisher
    With a machine like a Dual Action Polisher, the pressure is spread out evenly over the entire face of the buffing pad assuming you're using good technique and holding the pad flat to the surface.
    Wax Applicator Pad
    Your hand, which is actually 4 fingers pushing down on an applicator pad creates pressure points and cannot match, let alone outperform the equal pressure applied to the entire face of a foam buffing pad with about a 6" diameter by machine.
    So out of the 2 options, machine, wax applicator pad or bare hand, the machine option provides for the most even pressure when spreading out a wax, hand application offers some ability to spread out the pressure but when working by hand there's nothing to act as an interface between your hand and the paint.
    A Romantic Idea
    Melting wax with your hand is just a romantic idea, nothing wrong with that as it does invoke this perception of old world craftsmanship. That said, you can melt most paste waxes enough to liquefy them so the wax will flow into your applicator pad simply by spinning your applicator over the surface of the wax while it's in the can. M16 has been out since 1951 and all the old-timers knew this back in the day...
    If applying wax with your bare hand sounds like a good idea simply get a clean, foam applicator pad and then do your own hands-on test and try applying and spreading out a thin, uniform coating using both methods, hand and applicator pad and then come to your own opinion and then post it here to share with others.
    Learning 97 Supra's Avatar
    Dec 2007
    Phillipsburg, NJ
    165
    15
    Re: waxing by hand
    Read in bold if you don't wanna read the entire post.
    I do wax my cars by hand sometimes
    , but only because as some of you know I try to do everything the most time consuming and difficult way possible. If I can't do it with my bare hands or elbow grease, than I don't need to be doing it kind of deal.
    (don't argue this it's just the way I am.)
    I can tell you, that there is no benefit to waxing with your bare hands other than slightly more cut triceps. You may scratch your car if you have calloused hands, generally people's hands are NOT softer than fibrous towels or dense foam applicator pads so listen to me when I tell you - hand waxing is only for people who like to do things the hard way.
    One last note, if you feel you have extremely smooth hands, think again. Grab a microfiber towel and see if it feels like it's sticking to you. The day that it doesn't feel like it's sticking, is the day waxing with your hands would be better than waxing with a proper applicator pad.
    Registered Member Fischer's Avatar
    May 2008
    Marion, Indiana
    33
    533
    23
    Re: waxing by hand
    I just think doing it by your hands is just a hassel because even after you wash your hands, it still feels weird.
    Sep 2005
    14,253
    539
    Re: waxing by hand
    I would think that it would be hard to get a consistent layer of wax using your bare hands. I will stick with the G110.
    Dec 2008
    San Diego
    35
    6
    Re: waxing by hand
    Quote Originally Posted by J. A. Michaels View Post
    i agree...
    Jan 2009
    New Lenox, Illinois
    10,362
    302
    Re: waxing by hand
    very interesting, bare hands, i wouldnt want all the oils in the palm of my hand to go in the paint, still, fun idea i guess
    Registered Member Andy's Pro Detailing's Avatar
    Dec 2008
    Gainesville FL
    125
    14
    Re: waxing by hand
    hand waxing is great but not in cars though
    2008 Toyota Tundra DC SR5 4.7L V8
  1. Waxing by hand...really! lol
    By HammerDown in forum Working by Hand
    Last Post: Aug 27th, 2008, 07:15 PM
  2. Power waxing vs. hand waxing
    By Silverbaby in forum Detailing 101
    Last Post: May 16th, 2008, 09:30 PM
  3. Hand Waxing Vs. Machine Waxing
    By SPEED_DEMON in forum Detailing 101
    Last Post: Jun 17th, 2005, 05:16 AM
  4. 3 days of solid HAND waxing... (pics inside... sorry 56K!)
    By VanityDetailing in forum Show Off Your Latest Detail Work
    Last Post: Jun 10th, 2005, 09:40 AM
Tags for this Thread
