Tree sap removal
Results 1 to 10 of 12
Thread: Tree sap removal
    Jan 2006
    30
    15
    Tree sap removal
    I have a question for the group. How do you remove tree sap? I typically run into it here in NC. It usually is small about the size of a dime, and can range from sticky guey, to rock hard. Usually has a yellow color to it
    59
    24,767
    519
    Re: Tree sap removal
    Have you tried detailing clay after first washing the car really well?
    Jan 2006
    30
    15
    I haven't tried it but I would doubt that it will work on the rock hard sap, i often times can not remove it with my fingernail, it's usually mounded also. Somebody suggested Goof-Off which is a painters product, this worked great on the sticky sap, but will not touch the hardened.
    Registered Member Stangfan's Avatar
    Jul 2005
    113
    16
    I found some hard sap on my Dad's hood the other day after washing the car. Goo Gone took care of it. I did have to let the stuff penetrate the sap for a bit, but it all came off.
    1968 Mustang Coupe Candy Apple Red
    1990 Limited Editon Mustang 5.0 Convertible (7UP Car)
    Registered Member Princeslik's Avatar
    Mar 2007
    33
    14
    Have you tried isopropyl rubbing alcohol??
    Feb 2004
    Grants Pass, OR
    132
    18
    Quote Originally Posted by Stangfan View Post
    I have 3 pine trees...and a bottle of Goo Gone.
    Stang: Nice Mustang(s)...love the rare 7-up! I just sold my 87 LX 5.0 vert...but got an '07 GT .
    Are you on Mustang Source forums?
    Registered Member onawrxhigh's Avatar
    Jun 2004
    Ocean County NJ
    45
    619
    23
    Hey Donc,
    If you have rain-x give it a try. the solvents in it will breakdown the sap and it will remove very easily. For the really hard sap try soaking a rag with it and place it over the sap spot and let it sit for a little while(45 second to a few minutes and it should soften it enough to wipe it right off. Them remember to re-wax the area because the solvents in the rain-x will remove the old wax.
    Andrew
    2013 Race Red F-150 SCREW
    Mar 2008
    127
    14
    Don't mean to bump this old topic, but rubbing alcohol does the trick!
    My dad's prius had three areas of tree sap that hardened like a rock on the paint. I tried a few things such as clay and whatnot but nothing worked. Read about use alcohol so I did...
    As soon as the alcohol touched the sap it broke it down and came off like butter. Then I just used some cleaner wax on the area and was all set. Good as new!
    59
    24,767
    519
    Always test a product first to make sure it will work in one small area first, different types of tree saps are easier or harder to get off than others.
    Test, test test...
    Jul 2008
    West Virginia
    12
    I agree with invertalon. I had big gobs of soft tree sap and tiny hardened gobs of tree sap. For the big gobs I used Goo-gone to to remove the soft parts, then used the alcohol for all the hardened parts. I rinsed with water in between each alcohol application to remove the alcohol, then removed extra residue with more goo-gone. I was going to try UQD on some new tree sap spots that I've found, but I wanted to know if anyone has tried using UQD on tree sap and had any success?
    A problem did arise that I hope someone could help me with. There seems to be some lifting now especially where the hardened tree sap was. It can definitely be felt, but can only be seen with close inspection (during day, and with a light during night its easier to see with close inspection).
    I'd like to post pictures, but its very hard to photograph. What could I use to remove these easy to feel/hard to see spots and restore the smooth surface? I was thinking ScratchX, but wanted some opinions from MOL before I started anymore work.
    I was hoping to do this by hand as I only have an orbital buffer. It is also a new car with white pearlescent paint.
  1. Tree Sap
    By TrueBlue01 in forum Working by Hand
    Last Post: Feb 10th, 2009, 12:33 PM
  2. Pine Tree Sap Removal
    By QStorm in forum Detailing 101
    Last Post: Jan 26th, 2007, 12:56 PM
  3. Tree Sap-Help needed for removal
    By Dieseljoe in forum Detailing 101
    Last Post: Jul 2nd, 2006, 03:04 PM
  4. tree sap
    By bookofshadows4 in forum Detailing 101
    Last Post: Jun 23rd, 2006, 07:07 AM
  5. Tree Sap Etching Removal
    By zey in forum Detailing 101
    Last Post: Nov 26th, 2004, 03:43 PM
