Some people use it with a PC, but Meguiar’s does not recommend it for use with a PC. There is a difference.
You will be better off using a product like #83 DACP with the PC and if this is not aggressive enough to remove the defects, it could be that the defects will need to be removed using rotary buffer.
Mike
