OK, you can reply to this thread now, I split the days in to their own posts to narrow the problems when I copy and pasted, so.... I think I fixed all the problems. I can tell you there are way more than just the ' that cause issues when copying from word.
About a year ago I compared a few dressings in this post: Tire Dressing Test - 56K warning!, and now here are some others.
I have been waiting to do this test, I wanted a fairly dry stretch so I kept an eye on the forecast. It did turn out to be fairly dry then towards the end of the test there was plenty of rain and a few inches of snow, in the end it worked out rather well and this should give you an idea over different driving conditions.
I first scrubbed the tires with All Purpose Cleaner + and a Versa-Angle Tire Brush then just to make sure the tires were clean I used what was left of my NXT Generation Tire Cleaner and again scrubbed with a Versa-Angle Tire Brush and rinsed. I cleaned them with both the APC+ and tire cleaner to ensure a clean surface. I wiped dry then let them sit for about an hour making sure the water had evaporated.
Here is a tire all cleaned up and ready for a dressing.
Fresh Clean Tire:
I applied the following products as the directions stated on the bottles, I applied two coats to each tire to give even coverage. I then let the products dry for about an hour and took the first set of photos you see in this post, I was having a very hard time getting good photos as the sun kept coming and going, so the first photos are not the best.
Hot Shine High Gloss Tire Gel Left front tire
Gold Class Endurance High Gloss Left rear tire
All Season Dressing Right front tire
Hyper-Dressing Right rear tire
I checked the tires everyday. I am taking photos every other day or depending on weather conditions, I found in the prior test every day wasn't totally necessary as there was very little change during dry conditions.
Again I was having trouble with the photos sorry for the varying quality in the photos (its a little hard to tell exactly what the product looks like.
I did notice I was having trouble getting a nice even look to the tires with all the products other than All Season Dressing, I am guessing that the tire have something to do with this. I have not had this same trouble in the past on previous vehicles with the same products so it leads me to believe the tires have something to do with it.
Fresh Clean Tire:
