Gilmour Foam Gun - Page 6
Page 6 of 6 FirstFirst 123456
Results 51 to 60 of 60
Thread: Gilmour Foam Gun
  1. #51
    Registered Member chrisrefaei1's Avatar
    Jul 2013
    houston tx
    58
    7
    Re: Gilmour Foam Gun
    Quote Originally Posted by KidDetailer View Post
    http://www.youtube.com/watch?v=3a6VPPNC0oM this is how a foam gun can be effectively used
    Awesome, Great link KiddDetailer, I was just about to posted that same video or the other one where he uses the R8 NightHawk. But Everyone this guy is truly talented and knows alot of techniques. He's also now on the Drive//
  2. #52
    Dec 2013
    Massachusetts
    7
    The video uses the foam gun in an unconventional way that doesn't exploit the primary advantage of using foam versus a non-foaming auto soap, which is that the foam stays wetter longer, enabling the dirt to be lifted with less force/friction/scratching.
  3. #53
    Jul 2013
    houston tx
    58
    7
    http://www.youtube.com/watch?v=X0Sqi1lAj1A
    Here you go guys this is the correct way to use it. Not only does he show the proper way to use the foam gun, he shows the proper way of how to wash the entire vehicle. And the great thing is this is just a "basic wash" imagine his extensive washes.
  4. #54
    Dec 2013
    Massachusetts
    7
    Thanks for posting another AMMO product advertisement; however, for a video showing the ad-free, unaffiliated, proper use of the foam gun, search You Tube for Junk Man Foam Gun Part 3.
  5. #55
    Jul 2013
    houston tx
    58
    7
    Just so that you know, he's great friends with Meguiars and buddies with some high Meguiar's members on here. And so that you aware his motto that he uses is, "use whatever brand you like just use it often"
  6. #56
    39
    19,160
    237
    I think for average people, that would be using a bit more soap than needed. but for a delicate paintr, more soap/lubrication is good.
    For me, just spraying once over the panel seems to leave enough lubrication.
    And if it seem s to need more soap, can easily spray on more anytime.
  7. #57
    大家好 Late Bloomer Bunky's Avatar
    Apr 2007
    Raleigh, NC
    445
    18
    Larry at Ammo is one of the few that says fine scratches at the drying stage.
    Al
    ~ Providing biased opinions
  8. #58
    Still Learning KidDetailer's Avatar
    Nov 2008
    las vegas
    144
    Me using a pressure washer and foam cannon, I believe the Foam master with wash mit technique is a very good way to wash the car in the HOT DESERT HEAT.
    With my Foam cannon, Dwell time varies depending on soap and temperature. It can be annoying to wash a car outside with a time limit because it turns into a race rather than an enjoyment. With the foam master and wash mit technique, the car is kept wet at most times.
  9. #59
    Dec 2013
    Massachusetts
    7
    True, there's more than one good way to use a foam gun. If you're in the desert and drying time is critical, that's a whole different situation than we have here in New England in Winter!!
    I recently picked up a second, portable foam gun that has a hand-operated pump. It's too cold outside here in Winter to connect the hose, but between washings I have developed a useful touchless procedure that I can use in my garage. I use the portable foam gun to dissolve / loosen up the dirtiest areas near the bottom, then rinse it mostly clean with distilled water from a garden sprayer (so it leaves no spots), letting it run off into a wallpaper trough so it doesn't turn to ice on the garage floor. It's a quick process, and I'm pretty happy with the results.
    /Jim F
  10. #60
    Dec 2013
    Massachusetts
    7
    I'm going to do a partial take-back on my previous comment... It doesn't get enough of the film off, and spotting is still a problem. Still experimenting. Winter *****!
  1. A closer look at the Gilmour Foam Gun....
    By gb387 in forum Detailing 101
    Last Post: Nov 20th, 2010, 03:52 PM
  2. Gilmour Foam Gun... the first use -
    Last Post: Mar 17th, 2009, 06:19 AM
  3. For Sale: Gilmour Foam Gun.
    By Egleone6 in forum For Sale or Trade
    Last Post: Jun 7th, 2008, 03:18 PM
  4. Foam Gun
    By jezroj in forum Detailing 101
    Last Post: Dec 6th, 2006, 05:27 PM
  5. FS: Foam Gun w/DP Xtreme Foam Formula
    By mshu7 in forum For Sale or Trade
    Last Post: Sep 28th, 2006, 12:45 PM
