Can i PC Scratch X?
  • Can i PC Scratch X?
    Is it possible to do? if so is it better than 83 or is it better to do Scratch X by hand and then follow up 83, 80?
    Re: Can i PC Scratch X?
    Scratch X can be used by hand and PC. You may need to follow up with #80 or #83 only if needed.
      make sure that the scratch-x tube you buy has a yellow star on it and say the new version.
        How far would a tube go? How much to do a small car? Large car/SUV?Would you need to use the same amount of 83? Use 8006 pad? Work til abrasive breaks down, or what?
          Tube should last awhile. At least a few vehicles.
          I am not sure which pad to use as I work by hand and don't have a DA. From what I have seen though you generally will need to only apply a a small circular amount of product on the pad per section which is 2x2, I think.
          Good catch!
            Yes, use the 8006 pad and you will be set!
            Brandon
            2007 Black Chevy Avalanche
            My Albums: Avalanche
              Where would the star be? My tube has a star and the words "clearcoat safe" are inside the star.
                Here is a picture of the New Scratch-X.
                Silverfish, that is the right one.
                  Is it worthed to use scratch x on the really bad scratches and then follow up wit 83 and 80 or will 83 do the same job as scratch x?
                    Thanks...
