I just used some 0000 steel wool to clean my chrome exhaust tips and it worked great. It left no scratches at all.
0000 steel wool
Re: 0000 steel wool
Originally posted by Lydia View PostI was wondering that too.
I would use something intended for that, like Mike said, Metal Polish, instead of something abrasive...Attack life, it's going to kill you anyway.
Re: 0000 steel wool
Originally posted by Lydia View PostI was wondering that too.quality creates its own demand
Re: 0000 steel wool
Originally posted by 23jam View PostI always thought that one of the ideas here. Was to share, teach, explain techniques that reduce the possibility of inflicting scratches on our vehicles. Or on any part of them.
For decades we've all read about people recommending the very fine grades of steel wool for cleaning glass, now this thread about using it to clean chrome.
Steel wool, as fine as it may be available, is still steel. It may work, it may scratch, it may leave scratching or micro-scratching that can only be seen in the right lighting conditions.
Not sure if we would test it on anything that's important to us when there are other safer options available. If it works great, if it doesn't then you'll have scratched chrome and the only honest repair for scratched chrome is to re-chrome.
Re: 0000 steel wool
I tried 0000 steel wool on my stainless exhaust tip. It was so discolored, nothing would help it. So I thought I'd try the steel wool with my favorite metal polish, Meguiar's All metal polish. Well, It looks real good from a distance but there are a TON of fine scrathes in it. stay a way from it. Keep it on hand for glass if you like it.
Re: 0000 steel wool
Well the reason i used steel wool is because my exhaust tips were very dirty and i have used steel wool other times on various things and i have always been impressed with its cleaning ability, and that ever since i have used it it has never caused damage. As far as scratching, I dont have any scratches that i can see, i checked at many different angles and light conditions, I bought the finest grade i could find (0000) Maybe different manufactures coat the steel to prevent rust or use lower quality in the making of the product, it works for me and i am very happy with the results, by no means do i want to cause any damage to any bodys stuff, and even if you do put in some micro scratches those can be taken out with metal polish, right?
Re: 0000 steel wool
Did you use any lube when you used it? Like a quick detailer product. I have a chrome wheel that I bent this past winter I could do a little test on.
As for getting out the scratches once they are there. Unless some one has had better luck then I have. They are there to stay. You might be able to buff it out with some rouge but I have never tried.Scott
Re: 0000 steel wool
Originally posted by Thejoyofdriving View Postand even if you do put in some micro scratches those can be taken out with metal polish, right?Attack life, it's going to kill you anyway.
Re: 0000 steel wool
I don't dout your good results. I'm happy you had good results. For me, at any angle, you can see the light scratches. Up close. The way I used it was with car soap. Lots of suds and water after I spray and wiped off any loose dirt. I used my metal polish and all it did was give it a decent shine. It didn't remove any or maybe very few scratches that the steel wool caused.
Re: 0000 steel wool
Originally posted by Thejoyofdriving View Postby no means do i want to cause any damage to any bodys stuff, and even if you do put in some micro scratches those can be taken out with metal polish, right?
Take a 50/50 mix of iso alcohol and water and wipe down your chrome pipes. Shine a halogen light on the pipes and then tell us what you see....
Tim
Re: 0000 steel wool
fellows chrome is really no different then paint! I also polish/buff metal. sure the cheap chrome plating junk is like a really soft paint, but you can get fine scratches out of it too.like i said steel-chrome-stainless steel is just like paint it can (AND I DO!!!) get scratches,scrapes out by polishing/buffing it out with a buffer (like a bench grinder) or you can use a bench grinder set up to buff with. if you have some curb rash or scuffs , you can wet sand with anywhere from 600 grit up to 1500 just like paint then buff out with a 8'' or 6'' wheel from lowes or sears. anyways i have learned a lot from you guys , and if any one is interested or want me to explain more post back.''USE THE LEAST AGGRESSIVE PRODUCT TO GET THE JOB DONE RIGHT''
Re: 0000 steel wool
Originally posted by stang_krazy View Postand if any one is interested or want me to explain more post back.
However, it would be better to do this in a new, dedicated thread, not tag onto this on about steel wool.
Looking forward to it, thank you for chiming in!
