Flagship Premium Marine Wax - Improved
Results 1 to 8 of 8
Thread: Flagship Premium Marine Wax - Improved
    59
    24,767
    519
    • Increased beading / protection
    • Most durable protection in Marine line
    • Enriches color & gloss
    • Removes light oxidation, scratches & swirls
    FLAGSHIP PREMIUM MARINE WAX
    Dramatically enriches color and shine of fiberglass and gel coat surfaces. Effective in removing light oxidation and dullness, restoring gloss, and adding protection from UV damage.
    *Use wax only after the surface has been cleaned and restored to a “like new” or “average” finish.
    11 oz. M6311 (Paste) MSRP $14.95
    16 oz. M6316 MSRP $19.99
    32 oz. M6332 MSRP $35.49
    Mar 2010
    Ocean City, Md.
    Re: Flagship Premium Marine Wax - Improved
    Mike, after using a heavy oxidation remover, is this product good for the next and final step or should something else be applied before I use this?
    Thanks!
    Registered Member hemi's Avatar
    Dec 2009
    baltimore,md
    132
    12
    If you like the look of your gelcoat after you use your compound and it looks clear with no swirls or haze, you should be ok to just follow it up with Flagship Wax. or you could try some M45 to feed the pores and then follow up with the Flagship wax.
    Aug 2010
    Arvada Colorado
    I thought just putting Marine wax on my Gel coat would be enough to get rid of the oxidation on my motorcoach. I was mistaken. So I bought some #2 Fine -Cut cleaner to help get rid of the oxidation. It kind of works but I still have a uneven finish. Looking at it at a angle you can see the overlapping of the orbital polisher. this coach is 43' long and I don't want to keep going around it for the rest of my life. Are there any suggestions on this process?
    Registered Member Poki's Avatar
    Jul 2008
    U.S.A.
    547
    21
    Wax alone will not and was not intended to remove oxidation. You'll need to step up to a much more aggressive product and best to use a cutting pad on a DA. Take a look at #49, 67 and 91 for oxidation removal. You will most likely still have an uneven look depending on type, age and condition of your gelcoat. I have great results topping my oxidation removal product with a wax to even out the look. If your RV is not stored inside and depending on where you live, you may have to repeat this process a couple times each year at least.
    Barry
    Aug 2010
    Arvada Colorado
    Thanks for the ideas. I am having a hard time using the orbital polisher for the first time with the #2 Fine-Cut. It turns into a paste that I can hardly remove from the gel coat by hand. I am kind of leaning to going back to my standard hand application.
    Last edited by Freightlinercoachman; Aug 17th, 2010 at 07:50 PM. Reason: Bad spelling
    Loves to Detail TH0001's Avatar
    Feb 2006
    Orlando Florida
    39
    1,091
    133
    Quote Originally Posted by Freightlinercoachman View Post
    #2 fine cut may not have the abrasive power to cut through the oxidation on the paint, so while it cuts into the oxidation (and becomes contaminated, thus loosing cut) it clumps up and works into a paste.
    Try something that is a little wetter and has larger abrasive, like Heavy Cut Cleaner or M95 Speed Cut Compound.
    Then you can come back with the fine cut cleaner (make sure you are cleaning the pad frequently) and see if that helps.
    Jul 2008
    U.S.A.
    547
    21
    Let us know what make and model RV you have. You said it was 43ft. and that leads me to think it has full body paint with clear coat. Also, what kind of orbital machine are you using?
    Barry
  1. Flagship Marine Wax Separating
    By beeser in forum Meguiar's Marine/RV/Flagship Lines
    Last Post: Jun 30th, 2008, 08:26 AM
  2. New look for our Flagship Marine Line
    By Mike Phillips in forum Meguiar's Marine/RV/Flagship Lines
    Last Post: Dec 14th, 2007, 10:47 AM
  3. Flagship Premium Marine Wax
    By tguil in forum Marine & RV Line - Product Reviews
    Last Post: Sep 6th, 2006, 02:14 PM
  4. meguiars marine wax vs. 3m new Scotchgard™ Marine Liquid Wax
    By detailerrex in forum Meguiar's Marine/RV/Flagship Lines
    Last Post: Mar 28th, 2006, 10:25 AM
  5. Marine Flagship?
    By tguil in forum Meguiar's Marine/RV/Flagship Lines
    Last Post: Aug 22nd, 2004, 09:08 AM
