Today we had and unseasonally warm day (76*!!!!) So of course I had to break out the PC and some NXT.
During the rinse, I noticed that if I hit the car with a hard stream, the water beaded like crazy. If I flooded the surface, the water sheeted off VERY quickly. (It has been a bit over a week since I first applied the NXT and it has rained nearly every day).
Since last talking to Mike, I decided to use a Lake Country polishing pad instead of the finishing pad I'd used before. I was a bit more liberal with the #34 keeping the pad lubricated. I used less NXT than before, but in several areas I was getting the "first pass product on the car, 2nd pass product gone again" phenomenon. I also kicked the PC up to '4' this time.
Like I did last week, I applied a coat of NXT to the entire car allowed it to cure for 1/2 hour, buffed it off and applied a 2nd coat and allowed it to cure for a couple of hours then buffed it off.
That is where the question "2 coats or 4" comes from. I know common wisdom says "2" the second coat being applied so soon after the first only ensured complete coverage.
Whatever the case may be, the results are nothing short of incredible. I'll let them speak for themselves:
