Meguiar's New Detailer Line
Page 1 of 5 12345 LastLast
Results 1 to 10 of 50
Thread: Meguiar's New Detailer Line
    60
    24,761
    521
    Here are the part numbers, names and copy from the new Detailer Line listed in the order of Meguiar's new Professional Catalog. The entire Detailer Line is V.O.C. compliant in all 50 states.
    Super Degreaser
    Meguiar's Super Degreaser exceeds expectations by quickly breaking down even the toughest grease. Its fast acting, free rinsing formula prevents unsightly white residue stains while its herbal fragrance creates a pleasant work environment.
    D-10801 1 gallon
    D-10805 5 gallon
    D-10855 55 gallon
    Medium Duty Degreasing 10:1
    Heavy Duty Degreasing 4:1
    Safe D-Greaser
    Today's vehicles utilize a variety of specialized materials, which is why Meguiar's Safe D-Greaser has been specially formulated to reduce the possibility of staining exterior surfaces. Designed to quickly break down grease and grime on engines, tries and fender wells, Safe D-Greaser is ideally suited for today's fast paces, high volume shops.
    D-10501 1 gallon
    D-10505 5 gallon
    D-10555 55 gallon
    Dewaxing 20:1
    Recommended replacement for regular All Purpose Cleaner and Citri-Gel Multi Cleaner.
    All Purpose Cleaner
    Meguiar's All Purpose Cleaner is ideal for reconditioning interior surfaces. The superior foaming action gently lifts the dirt away while its unique blend of fabric softeners and optical brighteners enhance the look and feel of carpet, upholstery, vinyl and even leather.
    D-10101 1 gallon
    D-10105 5 gallon
    D-10155 55 gallon
    Recommended replacement for All Purpose Cleaner +.
    Hyper-Wash
    Typical dilution rates are obsolete when comparing them with Meguiar's Hyper-Wash. Using innovative techniques Meguiar's has created a product that produces rich, stable foam at an unbelievable dilution rate of 400:1 (yes 400 that is NOT a typo). Its biodegradable formula safely and effectively lifts dirt and grime off all surfaces.
    D-11001 1 gallon
    D-11005 5 gallon
    Dilution 400:1
    Recommended replacement for Car Wash Soap.
    Shampoo Plus
    Meguiar's Shampoo Plus lubricating formula and luxurious foam team up to gently clean and condition even the most delicate clear coat surface without scratching. Its conditioning formula deepens gloss, boost shine and leaves a highly reflective, slick surface making it the perfect choice for the ultimate car wash.
    D-11101 1 gallon
    D-11105 5 gallon
    D-11155 55 gallon
    Dilution 10:1
    Recommended replacement for Wash 'n Wax.
    Glass Cleaner Concentrate
    Our Glass Cleaner Concentrate easily and consistently removes tough vinyl fog residue, road grime, smoker's film and bug splatter, producing crystal clear glass. For every concentrated gallon, you get eleven ready-to-use gallons of glass cleaner.
    D-12001 1 gallon
    D-12005 5 gallon
    Dilution 10:1
    Wheel Brightener
    Meguiar's Wheel Brightener is the product of choice for professionals looking for a powerful wheel cleaner that quickly and effectively removes tough brake dust. There is a thin line between effective cleaning and dangerous to use products. Wheel Brightener gives users the ultimate in flexibility, cleaning and safety with one product.
    D-14001 1 gallon
    D-14005 5 gallon
    D-14055 55 gallon
    Dilution Up to 4:1
    Not for use on anodized, magnesium or polished aluminum wheels.
    X-Press Liquid Wax
    Meguiar?s X-Press Liquid Wax uses a unique blend of wax and polymer agents to produce deep, rich gloss with lasting protection. This formula provides ease of application and instant wipe-off, making it the perfect choice for any production environment where Meguiar's quality results are as essential as speed & efficiency.
    D-15001 1 gallon
    Ready to Use
    Application hand, orbital, DA or Rotary
    Recommended replacement for Express Wax.
    Last Touch
    Meguiar's Last Touch Spray Detailer produces incredible depth, shine and gloss. This spray-on, wipe-off product has a unique blend of polymeric lubricating agents that gently removes dust, fingerprints, smudges and other contaminates, leaving a flawless, showroom shine.
    D-15501 1 gallon
    D-15505 5 gallon
    Ready to Use
    Can be used as a lubricant for Meguiar's clay, dilute 1:1 for this application.
    Recommended replacement for Final Detail
    Body Solvent
    Meguiar's Body Solvent changes the traditional method of removing tar, road grime, gum and other petroleum based substances. Instead of applying and scrubbing, its VOC compliant formula can now be sprayed on the surface, allowed to soak, penetrate and break down the contaminant, then wiped clean with ease.
    D-13001 1 gallon
    D-13005 5 gallon
    Ready to Use
    All Season Dressing
    Meguiar's All Season Dressing is a VOC compliant formula that produces a deep, rich, long lasting shine on all exterior rubber and plastic surfaces. Old or new, weathered or worn. All Season Dressing will give you the desired results time after time.
    D-16001 1 gallon
    D-16005 5 gallon
    D-16055 55 gallon
    Ready to Use
    Recommended replacement for S-Dressing.
    Silicone-Free Dressing
    Meguiar's Silicone-Free Dressing is the choice for professionals looking for a high performance dressing which can be used in any silicone sensitive environment. Its VOC compliant formula produces an incredibly deep, rich high gloss shine on all exterior rubber and plastic surfaces.
    D-16101 1 gallon
    D-16105 5 gallon
    Ready to Use
    Recommended replacement for Silicone Free Tire Dressing.
    Hyper-Dressing
    Until now, the industry average for diluting water based dressings has been one to one or ready-to-use. Meguiar's Hyper-Dressing dilutes up to four to one, varying the gloss from high to satin. One product, multiple uses...a winning combination for every professional and an industry first.
    D-17001 1 gallon
    D-17005 5 gallon
    1:1 High Gloss
    2:1 Medium Gloss
    3:1 Satin Finish
    4:1 Natural Shine
    Recommended replacement for W-Dressing and Engine Kote.
    Accent Dressing
    Meguiar's Accent Dressing instantly beatifies and protects vinyl, rubber and plastic surfaces. This easy to use aerosol is ideal for exterior trim and hard to reach interior surfaces.
    D-4610 10 ounce
    Leather Cleaner & Conditioner
    Meguiar's Leather Cleaner & Conditioner is expressly formulated to enhance the appearance of interior leather and vinyl surface. Specialized cleaning and conditioning agents are designed to safely clean and restore leather's original look and suppleness.
    D-18001 1 gallon
    Ready to Use
    Secondary Bottles
    Touch, reusable spray bottles with silk-screened lables and pre-marked for dillution levels. OSHA Compliant.
    Hand Pumps
    These hand pumpls are pre-set to deliver the correct amount of concentrate according to the dilution level you choose.
    Detailing Clay
    Quickly removes all bonded contaminates
    Restores smooth as glass finish
    100% non-abrasive - safe on all types of paint
    Two grades available to suit your needs,
    Mild (C-2000) 200g
    Aggressive (C-2100) 200g
    Des Moines, Iowa
    42
    5,605
    78
    Great new products! What would be a good product to use in the engine bay now that EK is gone?
    Brandon
    2007 Black Chevy Avalanche
    My Albums: Avalanche
    Registered Member Bill D's Avatar
    Apr 2004
    352
    21
    Please try to have some of these items on tap at the NJ gtg and please have Rod urge PAL Automotive to stock the Detailer line! Thanks!
    my product collection-- New !
    My Detailing Credo
    Treat it like it's the only one in the world.
    60
    24,761
    521
    I have heard through one of my friends here at work that was directly involved in bringing forth the new Detailer Line that D170 Hyper-Dressing at 3:1 (in some cases, 4:1) is knocking it out of the park as an engine dressing.
    You might consider this and give it a try.
    Mike
    Registered Member JG_Detailing's Avatar
    Apr 2004
    Waynesburg, Pa
    50
    1,799
    39
    The new line of Meguiar's Professional Detailing look's great. I do have one question about the Last Touch. Will it be sold in store's or only online.
    Okanagan Valley, BC
    4,544
    395
    Hey,
    Meguiar's Last Touch should be sold and available in stores already. Great product! You will love it!!!
    Tim
    60
    24,761
    521
    The Detailer Line is available through PBE stores.
    Use this link to locate a store near your,
    http://www.meguiarsonline.com/forums...&threadid=1504
    Mike
    Mar 2004
    3
    18
    drool
    just wish we could get small size samples for us little guys
    Registered Member Scottwax's Avatar
    Feb 2004
    492
    22
    My Meguiars distributer (largest by far in the area) is not able to get Hyper Dressing yet. They did give me a half gallon jug to try out that they had used to give out smaller samples so I have enough for a few weeks. When will it be out?
    Registered Member Desertdawg's Avatar
    Aug 2004
    410
    22
    They were selling all of these today at the free clinic in Phoenix in the smaller spray bottles.
    I bought some Hyper Dressing and a tub of the mild clay, now to find the time to play...
  1. detailer line?
    By sstg in forum Detailing 101
    Last Post: Feb 23rd, 2008, 03:14 PM
  2. Discontinued Meguiar's Detailer Line
    By showtime in forum For Sale or Trade
    Last Post: Nov 11th, 2005, 04:58 PM
