Cleaning Your Pad On The Fly
Page 1 of 7 1234567 LastLast
Results 1 to 10 of 63
Thread: Cleaning Your Pad On The Fly
    60
    24,759
    520
    The question often comes up,
    How do I clean my buffing pads?
    Or more specifically,
    How do I clean my buffing pads after they become wet or saturated with the product I'm working with?
    One way is to do what we call, Cleaning your pad on the fly. This means to take and hold a clean, soft, dry terry cloth towel, hopefully a towel with a thick nap, (the little cotton loops), against the face of the pad while it's still on your polisher and then with your hand that's holding the polisher, use your finger to turn the polisher on and then move the towel around and against the face of the foam pad. This will act to cause the excess product built-up in the foam pad to move out of the pad and saturate into the terry cloth towel. Then you can place the towel down and get back to working on your car.
    This is called cleaning your pad on the fly because it's quick and simple and fairly effective for what you're trying to do.
    Here's Cisco from one of our recent Saturday Detailing Classes learning how to clean a pad on the fly
    Mike Stoops Cleaning a pad on the fly
    As you clean your pad you'll see residue build-up on the towel.
    Clean your pad often
    Besides knowing how to clean your pad on the fly you also need to remember to clean your pad often, usually after every other application of product to the pad. That is, apply some product to your pad and work it to a section. Wipe off the spent residue and either re-clean the area or move onto a new area. After a second application of product to the pad and after you've worked it to a section, now clean your pad. This is cleaning your pad every other application of product to the pad. You can clean your pad after every application if you like too. Most people don't clean their pads often enough, so err on the side of caution. Cleaning your pad often maximizes your effectiveness and thus your speed and quality of end result.
    Apr 2008
    Jakarta Indonesia
    114
    15
    Re: Cleaning Your Pad On The Fly
    Is it ok to clean pads with shoe polish brush?
    Registered Member TxRado's Avatar
    May 2008
    San Antonio, TX
    244
    16
    Quote Originally Posted by gioprivatemove View Post
    Hey thats a great idea. Those are made out of horsehair normally right? I would think thats a perfect texture based on the length of the bristles. Anyone ever tried this?
    Detailing Enthusiast
    May 2008
    San Antonio, TX
    244
    16
    The bottom one seems perfect for the job.
    Person PorscheGuy997's Avatar
    Apr 2006
    Southern Indiana
    1,344
    36
    Toothbrushes work when used to clean pads while using the rotary.
    I've never tried using a brush with the PC, but it doesn't sound like it would work.
    Chris
    Dasher Detailing Services
    Okanagan Valley, BC
    4,544
    394
    Quote Originally Posted by PorscheGuy997 View Post
    Hey Chris,
    Cleaning pads with a brush is for the rotary like you mentioned. With the rotary spinning around 1000 rpm, it is surprising how much stuff comes off of a pad from using a brush!
    But as you mentioned, using the brush with the machine turned on is not for the DA. You can brush the pad once it is dry to remove dried on product. But this is done with the machine turned off. If you attempt to do this with the DA turned on, like we do with a rotary, the pad will will fly off ruining the pad. The DA's action will fling a pad a long ways!!
    Tim
    Registered Member b2bomber's Avatar
    Jul 2006
    Malaysia
    55
    15
    nice tip. Thanks! one question, you seem to have specified (cotton) terry towels... can't MF towels hack it? TIA.
    Last edited by b2bomber; Jul 28th, 2008 at 09:55 AM. Reason: i forgot to add my question. :-P
    We Are Member VoicesInMyHead's Avatar
    Jul 2008
    Sun City, AZ
    609
    20
    Quote Originally Posted by Tim Lingor View Post
    ...If you attempt to do this with the DA turned on, like we do with a rotary, the pad will will fly off ruining the pad. The DA's action will fling a pad a long ways!!
    Sounds like I have my next competition with kerrinjeff! Wonder what the current record for distance is....
    --VoicesInMyHead--
    Armed w/105 and dangerous InfiniteDetail's Avatar
    Apr 2008
    Arizona
    1,050
    120
    Quote Originally Posted by VoicesInMyHead View Post
    Bring it on, I've been training for weeks!
    Nearly Car Crazy RacerX88's Avatar
    Jun 2008
    Greensboro-High Point, North Carolina
    536
    18
    What speed should you use to clean? I imagine since your holding the DA with one hand it's pretty low?
    Rob A.
    '07 Kia Optima (Gold)
  1. Is Cleaning Pad on the Fly nessecary for wax?
    By dragonballz in forum Detailing 101
    Last Post: Dec 28th, 2008, 08:58 PM
  2. Pad Cleaning
    By gjohn28 in forum Machines - The Dual Action Polisher
    Last Post: Dec 2nd, 2008, 11:32 PM
  3. Pad Cleaning?
    By lrtrees in forum Detailing 101
    Last Post: May 30th, 2006, 07:38 AM
  4. Pad cleaning
    By bimmer330i in forum Machines - The Dual Action Polisher
    Last Post: Dec 26th, 2004, 07:23 AM
  5. pad cleaning
    By DefJux921 in forum Machines - The Dual Action Polisher
    Last Post: Nov 25th, 2004, 03:42 PM
