How To Apply Interior Dressings
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: How To Apply Interior Dressings
    57
    24,767
    518
    Instead of spraying an interior spray dressing or cleaner directly onto the surface where overspray can be a problem, instead try this technique.
    Take a clean microfiber polishing cloth, foam wax applicator pad, microfiber applicator pad or even a household terry cloth wash rag and fold it at least 4-ways, (more if it's really large), and then dampen one side of it by spraying your choice of dressing or cleaner onto the cloth or applicator pad.
    Now take this dampened side of your applicator cloth or pad and use it to wipe down the appropriate surfaces in your car's interior always matching the correct product to the surface to be treated. By using this technique you have precise control over product placement and avoid getting overspray onto adjacent surfaces where you may not want a dressing or a cleaner.
    Using Quik Interior Detailer to clean the dash on a 1975 Jimmy
    Meguiar's Soft Foam Applicator Pad
    Meguiar's Supreme Shine Microfiber Polishing Cloth
    A clean, household wash rag
    If you're using a foam or microfiber wax applicator pad, first bury the nozzle into the pad then inject some dressing or cleaner into the pad. Squeeze the trigger slowly and allow the liquid to penetrate into the foam. It won't take much to give you plenty to spread around. Add more as needed and keep a clean dry polishing cloth around to wipe off any excess from the surface.
    Ick! Look at some of the dirt we're removing!
    Time for an Interior Extreme Makeover!
    Product selection is always important but just as important is the technique you use to apply the product.
    (Excuse the engine grime under my fingernails, when I took these pictures I just finished removing a 4-speed transmission and a NP205 Transfercase out of the rig I'm sitting in, a 1975 GMC Jimmy. -thanks... mp)
    Registered Member G Force's Avatar
    Dec 2007
    Mauritius
    345
    15
    Re: How To Apply Interior Dressings
    Thanks as from now i wont spray directly on surfaces to clean
    Sep 2005
    14,242
    536
    Thanks for the tips Mike. I never sprayed onto the surface always on the applicator. I will now spray the product closer to the applicator. That just makes sense. Thanks again Mike.
    Registered Member Cat's Avatar
    Jan 2008
    85
    12
    I just bought this product and haven't had time to use it yet - thanks
    for the great information. I have had a hard time finding something to
    work on the interior. The Honda Fit has a carbon fiber "appearance" on
    the dash and doors so I don't want product getting into the dimples and
    staying.
    Cat :x
    Jan 2008
    I Initially cover my hand with a latex glove, follow that with a microfiber mit... then spray my mit with detailer... that way, I have essentially infinite control over where the detailer gets spread
    aka Jeff Long Jossy92's Avatar
    Dec 2007
    SoCal
    74
    516
    51
    I sure appreciate these "technique posts".
    Success is never final, failure is never fatal. It's courage that counts.
    by John Wooden
    '88 Honda
    Registered Member SubieRon's Avatar
    Nov 2005
    Cerritos
    5
    14
    i spray my microfiber mit and i like the way it works
    Registered Member superbogel's Avatar
    Aug 2008
    Indonesia
    58
    o i c i wont spray into the surface anymore thx thx
    Des Moines, Iowa
    39
    5,605
    75
    I haven't sprayed the products on the surface for some time but I really like the idea of getting the product into the pad.
    Brandon
    2007 Black Chevy Avalanche
    My Albums: Avalanche
    Registered Member JTOWN's Avatar
    Oct 2008
    Australia Adelaide
    133
    12
    I havent tried this method and yeah i agree with you Cat the Carbon Fiber is hard to manvour around when just spraying, detailing a mates interior tonight and will instead spray onto the cloth...
    what about when the product says: if you want a longer lasting effect leave on surface for a couple of mintues?
  1. *how To Apply Tire Dressings (gel Type)*
    By The Doctor detailer in forum Tricks of the Trade!
    Last Post: Nov 11th, 2009, 04:30 PM
  2. How to apply properly apply compound?
    By sunfire in forum Detailing 101
    Last Post: Nov 21st, 2008, 08:14 AM
  3. Interior Dressings
    By Dj's Detailing in forum Detailing 101
    Last Post: Sep 8th, 2008, 07:47 AM
  4. About Dressings
    By drculinarian in forum Professional Line - Product Reviews
    Last Post: Aug 8th, 2008, 10:30 AM
  5. Dressings
    By Playr in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Apr 1st, 2008, 07:56 AM
