Polishing After 3000 Grit Sanding
Results 1 to 7 of 7
Thread: Polishing After 3000 Grit Sanding
    Nov 2006
    19
    14
    Had to do some sanding with 3000 grit, what polish should I use now? Would ScratchX do the job?
    Registered Member C30-Mike's Avatar
    Jul 2004
    226
    18
    Re: Polishing After 3000 Grit Sanding
    Follow up with M105 via rotary with a foam pad (yellow). You may have to go with a wool pad if the foam is not reducing the sanding marks.
    After M105 go to M80 with a rotary with foam yellow pad. At this point evaluate the results and use a PC or G110 with yellow pad with M80 to remove any buffer marks at speed 5.
    If you do a search there is an article on how to remove sanding marks.
    Registered Member Lt1Corvette's Avatar
    Aug 2004
    643
    22
    I don't think scratch X will cut it. Are you working solely by hand or do you have any machines?
    If it were me I would hit it with #84 on rotary with wool pad. Depending on condition #80 on a yellow or red pad.
    Nov 2006
    19
    14
    I'm working by hand and it's just a small spot. Would #80 by hand be enough?
    Registered Member yalerd's Avatar
    Jan 2006
    4,439
    121
    By hand is very difficult but you could try with a terry towel and LOTS of passion behind it. Your results will really depend on the type of paint you have.
    Good luck with it, but please next time, don't sand if you don't have a rotary.
    Registered Member Jeepster04's Avatar
    Jul 2006
    Eastern Kentucky
    1,248
    26
    #80 probably wont remove wet-sanding by hand.
    MAYBE #83 with a terry towel and alot of work.
    58
    24,767
    519
    Quote Originally Posted by JJ1 View Post
    You can try ScratchX if that's what you have, with a piece of terry cloth towel, after using the terry cloth towel you'll likely have to re-clean the area using a foam or microfiber applicator and ScratchX as rubbing hard with terry cloth may remove your sanding marks but it will tend to leave it's own scratch pattern behind.
    We've purposefully sanding paint with #2000, #2500 and #3000 and demonstrated that the sanding marks can be removed using ScratchX by hand, but it took a lot of rubbing and repeated applications.
    Mostly because the paint we've always worked in these demonstrations by luck of the draw trended towards being hard, not soft.
    Reality is, you are not going to know what you can do until you go out into your garage and give your product and process of choice a try.
    Just to note, usually what will happen is you're remove all the shallower scratches and this will expose and highlight the deeper scratches. You can remove these but you'll have to keep rubbing out the area.
    M105 is supposed to work better for removing scratches by hand compared to ScratchX, we have not personally tried this yet, but it's an option you can consider if ScratchX doesn't work. You can also try any cleaner/polish you might already have in your garage.
    Let us know how it goes...
    What are you working on?
  1. What grit papers for wet sanding
    By AeroCleanse in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Jan 25th, 2009, 09:52 AM
  2. Can You Use the PC to Polish-out #2000 Grit Sanding Marks?
    By JJ1 in forum Hot Topics & Frequently Asked Questions
    Last Post: Apr 15th, 2007, 10:02 PM
  3. intended use for 3000 grit??
    By steveo3002 in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Aug 18th, 2006, 07:00 PM
  4. 3000 grit... use #83?
    By integraoligist in forum Detailing 101
    Last Post: Jun 3rd, 2005, 11:08 AM
  5. 2000 Grit Sanding Marks
    By imp2000ls in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Mar 9th, 2005, 01:57 PM
