Applying Deep Crystal Polish
Results 1 to 8 of 8
Thread: Applying Deep Crystal Polish
    Registered Member 325i05's Avatar
    Dec 2007
    30
    12
    When applying Deep Crystal Polish to aclean finish I have read in the forum to work it in to get into the pores of the paint finish. Is it possible to work it in too much and cause damage to the finish? I guess what I am trying to find out is how long is enough using a PC to work the polish before removing?
    57
    24,767
    518
    Re: Applying Deep Crystal Polish
    Meguiar's Deep Crystal Polish is a non-abrasive pure polish, see this thread for clarification between a cleaner/polish and a pure polish.
    The 5 Step Paint Care Cycle
    The idea being to apply the product, work it well over the paint and into the paint to whatever level this is possible as some paints are more porous than others, by the way clear coats paints are not porous, or at least they are not very porous when they are new, as in a new car or a new paint job.
    Usually 2-3 passes over each square inch by hand or machine is the correct procedure and then wipe any excess product off.
    With a DA polisher, usually a speed setting around the 4.0 setting works pretty well with a W-8006 polishing pad.
    Hope this helps...
    Dec 2007
    30
    12
    Thanks for the reply mike. I will try it and see the results.
    Registered Member ahooah48444's Avatar
    Jan 2008
    Near Port Huron, MI
    54
    12
    Speed setting of 4 with a W-8006 pad, do you use a mf bonnet as well?
    Dec 2007
    30
    12
    Yea I do. Actually I have 3
    Feb 2008
    Springfield, VA
    31
    Mike or anyone, can you tell me what qualifies as a "pass?" One stroke, back and forth?
    57
    24,767
    518
    Quote Originally Posted by MBA-J View Post
    One stroke in one direction.
    In the swimming world, there are "Laps" and "Lengths", if you swim from one end of the pool to the other end of the pool, that's a "Length", if you swim to one end of the pool and back to the other end, (where you started), that's a "Lap".
    One stroke is one length
    57
    24,767
    518
    Quote Originally Posted by ahooah48444 View Post
    Speed setting 4.0 is good, usually bonnets work best for removing waxes because waxes dry making wipe off by hand or machine easier.
    Pure polishes are not supposed to dry, there is no benefit to letting a pure polish dry the benefit comes from the product being applied, once it has been applied and work in and over the paint, then you immediately wipe it off. This being true, the the pure polish will likely still be wet/most but not dry, what this mean is if you try to remove it with a bonnet on a DA Polisher is that the bonnet will become wet with product and it just won't work as well as your hand quickly and easily turning to a dry side of a wiping cloth.
    FWIW
    p.s.
    From the Hot Topics forum,
    Which products need to dry before removing?
    When it comes to paint care, often times we'll have members post to our forum, which products and procedures they're using to detail their car. In the process they'll mention how long they let products like ScratchX, or Deep Crystal Polish, or #7 Show Car Glaze, or M80 Speed Glaze dry before they removed it.
    A common question that comes up often on our forum and over at our Customer Care Hotline is,
    • "How long should I let a paint cleaner dry?"
      or
      "How long should I let a polish dry?"
    This is a common mistake and/or misconception about these non-wax products, or in other words product meant to leave protection behind on the finish after removal. With this article, we hope to shed some light on this topic and clear up any confusion there may be on which products need to dry before removing them from the paint.
    When working inside the Meguiar's line of product, whether that's our Consumer Line, our Professional Line, or even our Mold Release Line, the only products that need to dry, and the only products you should allow to dry are our waxes.
    All other products are formulated and meant to be applied, worked-in and then removed immediately afterwards. This would include,
    • Compounds
    • Paint Cleaners
    • Cleaner/Polishes
    • Pure Polishes
    All Meguiar's waxes should be applied, worked-in and then allowed to dry until they pass the Swipe Test.
    This would include all Meguiar's paste waxes, liquid waxes and even our spray-on waxes.
    We hope this helps...
  1. deep crystal polish
    By d.mopar in forum Meguiar's Consumer Line Products
    Last Post: Apr 4th, 2007, 05:44 PM
  2. Applying Tech Wax on top of Deep Crystal
    By jezroj in forum Detailing 101
    Last Post: Nov 10th, 2006, 07:27 AM
  3. Use Deep Crystal Polish as prep prior to polish.
    By Vincent in forum Detailing 101
    Last Post: Oct 31st, 2006, 03:32 PM
  4. deep crystal #2 polish
    By maxima2k2 in forum Detailing 101
    Last Post: Mar 22nd, 2006, 02:54 PM
  5. #81 Hand Polish versus Deep Crystal Polish
    By scrub in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Jul 6th, 2004, 08:38 PM
