Detailing question, could use a little help..
Results 1 to 10 of 16
Thread: Detailing question, could use a little help..
    Mar 2008
    14
    Gonna get the Mustang GT convertible out of winter storage very soon. '96, low low miles. It has a lotta wax (Meguiars) on it. The top is white. What is the best way to clean the paint completely of all the wax and start over? Would a polishing compound be a good start? I was gonna have it detailed, but seeing how i am about my cars, i would rather do it myself. The top is a real pain to keep clean. I own it but i almost never drive it. It's the wife's toy.
    Registered Member onawrxhigh's Avatar
    Jun 2004
    Ocean County NJ
    44
    618
    21
    Re: Detailing question, could use a little help..
    Quote Originally Posted by intimadator8 View Post
    intimadator8,
    If you're talking about the old style polishing compounds of the turtle wax verity that you buy at the local out parts store then you will introduce more and deeper scratches as these compounds don't readily break down as you work them against the paint. I would steer clear of these. What you need is a good paint cleaner like Meg's deep crystal step 1 paint cleaner. This is a chemical cleaner and will remove the wax and dirt from the paint without a problem. I would also suggest that you clay your mustang prior to using the paint cleaner to remove any bonded contaminants so the cleaner will work only on the paint and not first on the the bonded contaminants. I hope this helped answer your questions.
    Andrew
    2013 Race Red F-150 SCREW
    58
    24,767
    518
    Quote Originally Posted by onawrxhigh View Post
    intimadator8,
    Deep Crystal Paint Cleaner is a great way to gently clean the paint to remove everything off the surface and get down to a clean base to start with. It contains both chemical cleaners and diminishing abrasives but it is a very light or gentle paint cleaner, in fact it is a most gentle paint cleaner.
    intimadator8,
    Andrew
    Great answer and suggestion.
    Registered Member Freebird's Avatar
    Mar 2008
    8
    People are probably going to cringe when I say this... but washing your car with a mild and gentle dish detergent, like Dawn, would be a great way to get all the wax off your paint. Be warned, the initial results will be depressing. It'll be dull and all your cars flaws will be screaming out at you. Then maybe a paint cleaner for bonded surface contaminants.. and def. a polish to put the luster back in after the dish soap.
    Jess
    97 Pontiac Firebird Y87
    Mar 2008
    14
    After i do the paint cleaner thing, also the clay, is there anything before the wax that i should use? Or should i just apply a new coat of wax?
    38
    19,049
    235
    Quote Originally Posted by Freebird View Post
    So why do it? I'm not doing anything that dulls my cars finish, or taking any steps backwards.
    38
    19,049
    235
    Here are the two basic processes by hand:
    Full Detail:
    1. Wash
    2. Clay
    3. Clean - DC#! in general, ScratchX for bad spots.
    4. Polish - Pure Polish
    5. Wax - 2 coats
    Quick Detail:
    1. Wash
    2. Clay if needed
    3. ColorX
    4. Wax
    Jun 2005
    The Real NorCal
    4,115
    143
    Whenever anyone says this, I always wonder WTH they even got that idea?
    I have to add another NO to this suggestion. Dish soap is for dishes. Plus, it is more expensive than car soap anyways.
    Mar 2008
    8
    Well, he wanted to remove ALL the wax on his car. So isn't that "taking steps backwards" anyways?
    Jess
    Mar 2008
    8
    Quote Originally Posted by roushstage2 View Post
    Don't knock it till you've tried it
    Everyone has their own methods and oppinions.
    Jess
  1. Detailing question
    By NineD1 Slug in forum Detailing 101
    Last Post: Mar 11th, 2009, 03:38 PM
  2. Detailing Question
    By gators241987 in forum Detailing 101
    Last Post: Feb 28th, 2008, 10:28 PM
  3. Question about detailing
    By chvyeter in forum Detailing 101
    Last Post: Jan 1st, 2008, 01:05 PM
  4. new to detailing.. PC question...
    By jmanero123 in forum Detailing 101
    Last Post: Mar 2nd, 2007, 03:26 PM
  5. Detailing question
    By realitycheck in forum Detailing 101
    Last Post: Aug 9th, 2006, 07:03 AM
