What's the best follow-up to #83 DACP?
I cleaned my Vette last evening, and noticed that a dirty waterspot (which I regretably left on my car for nearly a week) had etched the clearcoat a little.
Not wanting to leave the etching in the paint, I broke out my products. I've read over and over to use "the least agressive method first", so I tried the SMR that I had (It happened to be the 3M SMR) with the PC and a yellow MEG's pad on 3 setting. The SMR had little effect on the etching. So, I broke out my next most aggressive polish, #83 and the only other pad I had available to use with the DACP, a yellow CMA cutting pad. I used this at 5 setting and this worked quite well on the etching. It's still there, but VERY hard to see.
I followed the #83 with the SMR again.
Once I finished, it looked pretty good, but there was still some very slight marring (I think that's the right term) left. I suspect, I need something a little less coarse than the #83 to really take the shine to the level I want.
What would be the suggested next step? Should I get a polishing pad and use the #83 again, or should I get some #82, #81, or #80 and use a polishing pad?
What is the primary difference between the #80, #81 and #82??
Thanks for any advice.
