My 2006 Jeep aluminum wheel which is clear coated has a small spot where the clear coat is white/bubbling.it is not covered by a warrenty.Can this be repaired by me and if so how?Thanks Joe
Aluminum wheel corrosion
Re: Aluminum wheel corrosion
You would have to find a way to remove the lifting/corroded paint to get to a solid metal base and then somehow clean/scuff the metal portion and the surrounding paint, and then apply some clear touch up paint.
With a little perspiration and ingenuity you cold touch it up.
