Washing Question? Start at the top or start on the wheels?
View Poll Results: Washing your car, do you start on the top or wheels and tires first?
Voters
379. You may not vote on this poll
  • I start washing at the top of the car and work my way down finishing with the wheels and tires
    145 38.26%
  • I wash and rinse the wheels and tires first and then move on to the body
    224 59.10%
  • Other - I'll post my method of madness!
    10 2.64%
Page 1 of 6 123456 LastLast
Results 1 to 10 of 60
Thread: Washing Question? Start at the top or start on the wheels?
    59
    24,767
    519
    Poll: Car Washing Style?
    When you wash your car or a customer's car,
    • Do you start at the top of the car and work your way down?
    • Do you start with the wheels and tires and after you're finished with the wheels and tires you switch to the exterior body starting at the top and working your way down.
    • Or do you have some other method to your madness?
    Meguiar's recommends starting at the top and working down, for example starting on the roof of your car and working your way down the car.
    Some people like to wash the wheels and tires first and after washing and rinsing the wheels and tires then they start at the top of the car and work their way down.
    The reason for this is because if you wash the car starting at the top and working down, you have a wet car with water on the paint in the process of drying. While this water is sitting on the paint drying and potentially leaving a water spot, you're washing 4 wheels and tires, this takes time and while you're doing tis some water may dry on it's own before you can finish the wheels and tires.
    If after washing the car you then dry it, and now start washing the wheels and tires, you usually get water spray on the paint and this could include dirt from off the wheels as you were spraying them, so now you'll have to wash and rinse the affected area again.
    So for the above reasons, some people will wash the wheels and tires first, then wash the car. By doing it like this you don't have to dry the paint twice, nor rinse any of the paint a second time around the wheel wells. Then immediately after you give the car a final rinse you can being drying the water off the car. Since you're finished with the water hose and you won't be spraying water any more, then you won't be getting the car wet again and you should have enough time now to dry the water of the car without any risk of water spotting.
    Personal preference.
    Feb 2007
    289
    16
    Re: Washing Question? Start at the top or start on the wheels?
    Typically, I spray down the wheels and tires with a cleaner first and then prep my cleaning supplies. With the product still on the tires/wheels I proceed to wash the car from the top down using whatever soap water is left to brush the wheels.
    I then rinse off everything at one time.
    39
    19,184
    237
    I do wheels first, the roof, then hood/trunk, then sides....
    Avatar Czar BlueZero's Avatar
    Aug 2006
    Green Bay, WI
    3,314
    49
    I work top down. If the wheels are nasty I'll spray them with some cleaner first so they have time to soak. Then I use the left over wash water to do the wheels then tires. If they are chrome or something that will show swirls or the left over water looks pretty dirty, I'll get clean water.
    Scott
    Mar 2008
    53
    I usually do the rims first due to washing the wheels last water gets on the car and you have to clean it again.
    Registered Member Derrick's Avatar
    Mar 2008
    San Antonio, TX
    541
    19
    I clean the rims, tires, and wheel wells first then move onto the body and move from top to bottom. Finally after its all done i dress the tires and wheel wells.
    Jon's Premium Auto Detailing
    210-281-8151
    Clean Freak Kooz's Avatar
    Apr 2008
    Iowa
    48
    135
    14
    This is exactly what I do. Couldn't have said it better.
    Got Megs? Jokeman's Avatar
    Apr 2007
    Boston
    789
    21
    Quote Originally Posted by Derrickg32069 View Post
    Yup, that way there is no "overspray" on freshly cleaned paint.
    Apr 2008
    Monterrey Mexico
    7
    mmmm ... well now i'm a little worried, looks like i'm the crazy one here ..
    I usually wash my car once a week (if weather isn't bad). This takes about 1 to 1 1/2 hours. I start by jacking up the car and take the wheels off, wash the wheels and tires both sides, wash wheel wells. Then exterior car wash top-down doing one panel at the time (wash and dry).
    Dress wheel wells and tires ... put them back and lower the car.
    Jun 2005
    The Real NorCal
    4,116
    145
    Option 2 for me.
  1. Start-Up Question
    By Forever New in forum Detailing 4 Dollars
    Last Post: May 28th, 2008, 07:48 AM
  2. Before Start My Detail.....m21 Question
    By LOBO in forum Detailing 101
    Last Post: Mar 15th, 2007, 06:33 AM
  3. Where do I start?
    By genee in forum Detailing 101
    Last Post: Aug 7th, 2006, 06:05 PM
  4. New H2...where do I start??
    By jtower1969 in forum Detailing 101
    Last Post: Mar 30th, 2006, 04:16 PM
  5. new start.....
    By the newbie in forum Detailing 101
    Last Post: Jul 9th, 2004, 08:39 AM
