some nasty stains on my exhaust tip. what should I use to get it off and shine it up?? I got a picture:
what should I use to polish my exhaust tip??
Re: what should I use to polish my exhaust tip??
I dunno about #0000 steel wool.. never used it. Certainly got good results with terry alone. I'd do the milder terry first.
And it is Meguiars Hot Rims Mag and Aluminum Polish.....2017 Subaru WRX Premium - WR Blue
The reason I suggest steel wool is it looks like there is rust? To clarify, don't polish with the steel wool. Just get it wet and gently rub it which should loosen up all of that rust. Then polish it up with the Hot Rims Mag & Aluminum polish. If it isn't rust, go with just the polish first like Murr said.
Originally posted by Racingfan View Postsome nasty stains on my exhaust tip. what should I use to get it off and shine it up?? I got a picture:
try using meguiars new hot rims chrome polish liquid, and apply some on a terry cloth towel or MF first and rub in on surface of exhaust tip to see if any improvements.
If not then use the 0000 steelwool and soak the steelwool with the hot rims chrome polish (always keep the steelwool soaked with whatever product your using to keep from putting scratches or swirls on your surface)and gently rub on surface to remove the surface rust.(after finished with the steelwool put in a zip lock bag to keep for future use)
Then buff off with a MF and apply another coat of hot rim chrome polish by hand and polish off with a MF.
Let us know your results which everway you decided and your outcome.''USE THE LEAST AGGRESSIVE PRODUCT TO GET THE JOB DONE RIGHT''
Be careful with the steel wool, it could leave tiny scratches. Then agree with others, Hot Rims Aluminum/Chrome polish (black tin), stuff works great. Also, there is a new bottle of Hot Rims Chrome polish.
Use least aggressive first!
L8R
AaronPhilippians 2:14 - Do all things without grumbling or questioning,
WD-40 works well for road tar on paint. Since it's chrome, maybe a solvent of some type (gas) on a rag and wipe off......Philippians 2:14 - Do all things without grumbling or questioning,
