Can someone please tell me WHY they even give you a Speed 6 on the G110 when they tell you NEVER to use that speed. [Is this like the one forbidden fruit in the Garden of Eden]?
WHY Speed Level 6 on the G110?
Re: WHY Speed Level 6 on the G110?
USE SPEED 6.
I think they say that because you may get premeture pad failure. I find this more of a reason to not use the Megs pads than to not use speed 6. I never use anything but speed 6 when doing correcting work and I get so much better results than when I was stuck at 5. Seriously use speed 6 and if your Megs pads start to break up then just switch to the Lake Country Pads. the 5" and 5.5" Lake Country pads correct better anyway.
Might be there for the future!
Have you ever noticed we come out with new products, new technology?
Just recently we launched D151, earlier this year we launched M95, M105, M21 2.0, NXT 2.0, M135, UQD... these have all been introductions of *New* technology. Who knows what's around the corner?
Does the G110 run on 1.21 GIGAWATTS?!?!?
Before I started using a rotary, I used to use speed 6 all the time on the PC. You can see some increased pad wear around the adhesive patch for the backing plate if you do it a lot. Simply it does a little more work a little bit faster. Its' not that big of a deal.
Originally posted by Mike Phillips View Postthese have all been introductions of *New* technology. Who knows what's around the corner?
Sorry, just having fun with the cool smilies I do not have on other boards
Why....
Instead of developing a motor from scratch, which would be very costly, we sourced one that best fit our needs, and implemented it into our new G110. This means we had to be sensitive to the higher OPMS's....With that said, we must comment on the following statements.
Originally posted by CleanGSR View PostUSE SPEED 6..
Originally posted by CleanGSR View PostI never use anything but speed 6 when doing correcting work and I get so much better results than when I was stuck at 5..
Originally posted by CleanGSR View PostSeriously use speed 6 and if your Megs pads start to break up then just switch to the Lake Country Pads. the 5" and 5.5" Lake Country pads correct better anyway.
2 statements we live by and need to stress...
Always use the least aggressive method.
It is always to be safe than sorry.
MikeMike Pennington
Meguiar's, Inc.
800-854-8073
mpennington@meguiars.com
White 1967 Pontiac GTOBlack 2009 GMC Sierra SLT
Originally posted by cyberized View PostCan someone please tell me WHY they even give you a Speed 6 on the G110 when they tell you NEVER to use that speed. [Is this like the one forbidden fruit in the Garden of Eden]?Originally posted by Mike Phillips View PostMight be there for the future!
I've had good luck with my G100 at speed 5. With the increase in DA-approved products that provide more cut than previously before, the products are strong enough to get the good paint correction at speed 5, not speed 6.
For instance, I used D151 w/ G100 this past weekend and had really good results. Did it correct everything? No, but it did a good job.NOTE: Post count does not reflect actual detailing knowledge.
