Hey all,
I plan on painting something shortly and I have a question about how to go about it. I plan on getting color-matched paint in a spray can. I'll spray on 2-3 coats, lightly wet-sand to remove any orangepeel, apply another 2 or so coats and lightly wet-sand again. After that, I plan on applying a few coats of clear and wet-sanding that with a very high grit paper.
My question is about what kind of polish I should follow-up with. I realize the finish will look dull and hazy due to the wet-sanding marks. I don't have a polisher, so I need something that can be worked in by hand and remove the scratches. I was recommended #105, work it in by hand and it'll make the finish shine.
I was also wondering if anyone could recommend a good spray-on clear coat and wet-sanding paper that they've used? I can't remember which product I used last time, but it (the clear coat) went on very badly so I'd like to try something else. I've used 3m's wet-sanding automotive paper, but every time it leaves black smudges in the paint, no matter how lightly I sand. Drives me nuts.
Thanks a lot for any help!
