Re: M84 + Wool on rotary = Not enough
If everything you've tried so far is having little or no effect then it might be time to get a second opinion, is there anyone you now with years of polishing experience you could show this to?
If you're not making a dent in the swirls that are already in the paint then it's going to be hard to remove sanding marks also. If the paint is truly the problem here, as in it just is not very polishable then it might be time to walk away from this project.
This is a good tip, just make sure you don't get the paint too hot, you should always be able to place the palm of your hand onto the surface without finding yourself jerking your hand away quickly because it's too hot.
Originally posted by 2hotford
View Post
