Any wax that works fills to some degree
The topic of waxes and filling comes up often enough that it deserves it's own thread in Hot Topics to help remove any confusion. Most of the confusion can be found on other forums where someone is trying to make the case that any wax that fill is a bad thing.
That's convoluted thinking and it would be interesting to see how someone could explain how a wax or a paint sealant can leave its protection ingredients behind on the surface and not fill or coat over at the same time?
You see, any wax or paint sealant that works, that is any wax or paint sealant that leaves itself behind to protect the paint, (and isn't that the purpose of wax or a paint sealant, to leave itself behind?), is going to fill, (at least to some level), because it's coating over and bonding or adhering to the paint.
This being true, and so far no one has ever proved it's not true, then if a wax or paint sealant is really working then it's filling to some degree because it's leaving itself behind on the surface and thus coating over the surface and filling in low areas.
Conversely, any wax or paint sealant that's not leaving itself behind is not filling and thus it's not working and if this is the case it's time to quit using that product and move on to a product that's actually working.
That doesn't mean the purpose of a wax is to fill as the purpose of a quality wax or paint sealant is to protect, filling is just a physical characteristic of how it protects.
Anytime you find yourself on another forum and someone is trying to convince you or others that a wax that fills is a bad thing, then share the link to this thread with them and see if they can make their case that what is written here is wrong. In other words see if they can make the case that a wax or paint sealant that doesn't leave itself behind is actually working, that is it's actually doing what it's supposed to be doing.
Hope this clears up any confusion...
"Any wax that works fills to some degree"
