91 not enough
Results 1 to 3 of 3
Thread: 91 not enough
    Jun 2008
    picktown
    14
    91 not enough
    i just purchased a bottle of #91 marine compound. i was told this was told this was a super fast/strong cut for gel coat. i used it with a rotary and wool pad. it did not work as i would have liked. it loaded up the bonnet.
    i then picked up some medium cut. i like the way this worked out but i still need more cut. my gel is pretty fadded. this medium took 5 applications over the same 12" section to get back to the red color i am looking for.
    is there a meguiars compound that cuts like 1000 grit but works out like the medium cut.
    60
    24,759
    520
    Re: 91 not enough
    What are your working on?
    How old is it?
    What condition is it?
    What is your goal?
    Can you post a few pictures?
    Registered Member 70olds442's Avatar
    Jun 2008
    Centerville Ohio
    20
    Re: 91 not enough
    Matt.. I just did the same thing and had similar results.. I wondered if it was the way I did it.. The gelCoat sucked up the 91 like nobodys business and dried in seconds.. I added more H2o and that helped but not much..
    I am workin on an 84 Formula with very heavy oxidation.. I let it out in the sun and hadn't cared for it for years.. Now, I need a miracle..
