Hello Guys,
Please help with info.
Went through the site and could'nt find info on this..
I make Custom Cue Caps for Pool Cues and need Automotive Tech. Info.
on Clear Coat Finishing.
1. I just finish spraying Polyurethane Clear, Several Coats to make one Thick Coat.. on my Caps. It's now Dry..
2. I wet sand back till it's smooth and level, with 400, then 600, then 1500, and now 2000..
I have:
a) Scratch X,
b) Showcar Glaze #7
c) NXT Tech Wax.
Question -
1. What step(s) am I missing between the 2000 Grit Wet Sand and the Scratch X?
2. What step(s) am I missing between the Scratch X and the Showcar Glaze #7?
3. Want am I missing between the Show Car Glaze #7 and the NXT Wax?..
I don't have and can't use a spray gun, so, I use Min Wax Clear Gloss Polyurethane from a Spray Can.. I cannot start using a pro set-up and start mixing, the cost would make the Cue Caps too expensive..
The clear coat is O.K.
I just need advice how to bring the surface from a 2000 grit wet sand to
a "Crystal Clear" Glass like Surface Finish.
BTW, The NXT Tech Wax makes my caps so slippery, they squirt out of my fingers and can fall and get damaged.. I gotta warn my customers to open them over a soft surface so they don't Squirt out on them when unwrapping them upon receipt.. Amazing..
Thnaks for viewing and your help... Alton - Cue Caps Hawaii
I have:
a) Scratch X,
b) Showcar Glaze #7
c) NXT Tech Wax.
Question -
