I recently purchaced a PC to try and get some scratches out of my 2004 Black Corvette. I tried using a polishing pad with DACP and made the scratches a lot less noticeable but when I took it out in the sun it had what I guess you would call micromarring. I posted a question about this recently but it was lost on the weekend the website was hacked. I was advised to use Speed Glaze #80 or the Swirl free polish #82. I decided to try using both. I started with the #80 using a polishing pad and finished with #82 using a finishing pad. I did this at the end of the day because I have to work outside and is the only time it is shady. So when I finished it looked great. That is until I took it out in the sun and it still has the very fine small scratches instead of the crystal clear finish the rest of the car has. I went over a slightly larger area than when I originally did with just the DACP and I have the marring on that area as well so I guess the speed glaze did that also. I cant understand what I am doing wrong. I have the PC set to 5. Maybe I should use only the finishing pad with both products or maybe I need to work it in longer.
This is driving me crazy. Help!!
