How to apply product to the face of your foam buffing pads
Results 1 to 10 of 13
Thread: How to apply product to the face of your foam buffing pads
    59
    24,767
    519
    Below is how to apply fresh product to the face of you foam buffing pad when first starting out and your pads are dry. After you break you buffing pad in by working this initial amount of product over a section of paint, you can cut down on the amount of product you're using as the pad will be less likely to absorb as much product as it will become damp with product.
    Remember don't turn the polisher on until the face of the foam pad is in contact with surface of your car's paint.
    Quickly spread the product out of the surface you're going to work then slow your arm speed down and begin to use overlapping motions to work the product.
    After working an application of product, wipe the leftover residue from the worked area and inspect, if the results look good move onto a new section overlapping a little into the previous section. Continue this procedure until you have finished a panel or the entire vehicle.
    Remember to clean you pad on the fly and and to do this often. This insures the best experience while machine cleaning and polishing as excess product build-up on a foam buffing pad can cause gumming up.
    See the below thread for related information...
    Tips & Techniques for using the G110, G100, G220 and the PC Dual Action Polisher
    Cleaning Your Pad On The Fly
    How many passes to break the diminishing abrasives in M80 down?
    PC + 83 not "Cutting" it! (The Limits of Dual Action Polisher)
    How to tape-off a car
    Please explain Pros/Cons between Rotary and Orbital Buffers
    The Dual Action Counterweight 'Controversy'
    Cutting Pads with the PC - Is this a good idea?
    G100/PC - Should it be spinning all the time?
    The words Clean and Cleaning as defined by Meguiar's terminology
    Can You Use the PC to Polish-out #2000 Grit Sanding Marks?
    Which products need to dry before removing?
    Or if your the creative type like Joe at Superior Shine you can freestyle when placing fresh product onto the face of your foam pad.
    #21 Addict EAT HEMI's Avatar
    Jan 2008
    151
    14
    Re: How to apply product to the face of your foam buffing pads
    I am an X'r.
    Registered Member AeroCleanse's Avatar
    Dec 2007
    Neenah, WI
    1,116
    24
    For M83 I use three "dots" more than that seems like it too much.
    59
    24,767
    519
    Quote Originally Posted by AeroCleanse View Post
    Each person has to find what works best for them on the paint system they're working on at the time. In most cases, when starting out with a dry pad you want an ample amount of product to start the process, after you've broken in your pad you can cut down on how much product you're using and you temper this with how the product is working on the paint system you're working on.
    Most people do over use product and that's a problem, but you also don't want to under use product as that will cause problems too...
    Apr 2004
    151
    18
    Mike could you post up a pic of how and what amount of product you would apply to a pad that has been used and already absorbed product?
    Registered Member buckshot333's Avatar
    Dec 2006
    90
    14
    Quote Originally Posted by 99GrandTouring View Post
    I'm curious to see this as well.
    Dec 2006
    90
    14
    Bump
    Apr 2008
    38
    Hi Guys,
    I took the Saturday class in July & relied on memory as to the amount of product to use on my pads. Also the pads instructions called for 'priming' the pad before use, with a specific recommended product. Priming seems strange, given that the recommended priming product, most likely won't be the products intended for use.
    How about an insert 'paper' actual size of the pad, that has a pattern, (think black felt marker) one could use as a guide, for preventing gross over/under usage of product. The pattern would (similar to M. Phillips picture(s) product on pad) be a convenient visual reminder, for newbies, ballparking product usage.
    Inserting a guide poses an expense to Meguiar's, so perhaps 'printable' target(s) could be posted at the forum, as a trial. Should one product require more or less product then a separate, printable target could be posted, identifying specific product. Personally I would like to see the pattern built in or part of the pad itself.
    Take Care
    Rico
    59
    24,767
    519
    Quote Originally Posted by Rico View Post
    Hi Guys,
    This one?
    Open Class - July 26th, 2008 - Pictures & Comments
    That was a large class, which person were you?
    Priming is usually done for cutting pads using a quick detailer like Quik Detailer and usually when using a rotary buffer, not a DA Polisher and that's because bringing a coarse, DRY foam pad spinning at around 1500 RPM onto dry paint will heat the paint up very quickly and there's the potential for burning the paint.
    With a DA Polisher the pad is oscillating and the action is gentle and at this time we don't recommend using a cutting pad so that leaves just our soft polishing and finishing pads thus little or ZERO potential for burning he paint and therefore no need to prime the pad with a mist & wipe product like Quik Detailer.
    Some people also prime their pads with the chemical they're going to be using with the pad for a host of great reasons Kevin Brown addressed in this thread.
    Priming a Pad
    Rotary Buffers and DA Polisher are dramatically different tools in how they function and the dangers or lack thereof they present.
    How about an insert 'paper' actual size of the pad, that has a pattern, (think black felt marker) one could use as a guide, for preventing gross over/under usage of product. The pattern would (similar to M. Phillips picture(s) product on pad) be a convenient visual reminder, for newbies, ball-parking product usage.
    Take Care
    Rico
    Great idea, maybe copy and paste the last two paragraphs and post them here,
    New Product Suggestions
    Registered Member chessplayer's Avatar
    Sep 2006
    258
    17
    very good info mike i thought i was using a little too much product
  1. How to clean Meguiar's foam buffing pads
    Last Post: Jun 12th, 2019, 06:25 AM
  2. The 1965 Wooless Wonder - First Foam Buffing Pad
    By Mike Phillips in forum Blast From The Past
    Last Post: Aug 7th, 2010, 12:02 PM
  3. Storing Foam Buffing pads.
    By acsuppa in forum Detailing 101
    Last Post: Jun 30th, 2006, 06:14 PM
  4. buffing foam or wolly
    By steve-0 in forum Introduce Yourself - New Members
    Last Post: Apr 14th, 2006, 09:50 AM
