Shelf life of pre-diluted car wash detergent?
  • Shelf life of pre-diluted car wash detergent?
    Just wondering whether pre-dilution of a car wash detergent would reduce the shelf life of the detergent. I.e, if I pre-dilute and store it, will the detergent have the same potency after months or years, or does the fact that it's mixed with water cause it to diminish at a much faster rate, for whatever reason? (I'm guessing probably not)
    The reason I am interested in diluting it is for a foam-gun solution.
    Regards,
    Greg.
    Re: Shelf life of pre-diluted car wash detergent?
    There shouldn't be any fall-off in performance of the normal amount of time you would go in-between using the foam gun again to wash your car.
      Good heavens - thanks Mike, but I hope you haven't been researching this for FOUR MONTHS! Btw, looks like forum notifications are working - I received an email
      Note that the reason I asked the question is that I may actually not use it for a relatively long time - many many months perhaps. I know it's no big deal - I could just mix it up when required, but I was just curious about it.
      Cheers,
      Greg.
        Found your unanswered post doing some forum maintenance... sorry for the delay...
        Cheers,
        Greg.
        I still don't think you would see enough of a fall-off in performance to notice, and likely none at all.
