My car leaked some a little oil on concrete and it is proving very difficult to remove. Do yall have any tips or tricks to get it off?
Getting oil off of concrete
Re: Getting oil off of concrete
Originally posted by onnfire View PostIve just tried some soap and water so far. It wont get rained on though, it is in the garage unfortunately.
What I did was soak a few rags in gasoline and scrubbed off what I could off the surface. Then the next morning I went out there again with the simple Green (full strength - not diluted) and cleaned up the rest with a few shop rags.
Now you may be left with a little staining depending on how bad it was when you started but you should end up with a surface that you can walk on with out residue getting on your shoes or tires of your car.
I also used the same process outside where the concrete surface was more pores and was able to pull up a lot but there were some deeper stains down in the pores that did not come out. I'm sure if I went out there with just a pressure nozzle on a hose and worked it I could remove most of the staining.'08 Accord Cooooupe!
If you've got it try some wheel brightener, it worked so well for me that is the concrete looks like new and I had to do the rest of the it.The Best Last Step, is the step backwards you take to admire your work!
Originally posted by Mike PhillipsIf you use #7 on your car, you're not in good company... you're in GREAT company!
