How to quickly, easily and accurately mix your car wash solution
You know, when it comes to washing our cars, we know most people don't measure their car wash soap because they don't have a system to measure the car wash solution for their wash water bucket.
So what most people do is fill their bucket with water and then remove the lid from their car wash solution and start pouring car wash into their bucket of water like this,
Glug, glug, glug glug glub...
Their system relies on the Guesstimation Technique.
Am I right?
(Yeah I'm right)
Most serious enthusiasts use a 3-5 gallon bucket of water for their car wash solution, with most people using some type of 5-Gallon bucket with anywhere from 4 gallons of water to 5 gallons of water in the bucket.
Just a guess but probably pretty accurate as far as serious enthusiasts are concerned.
The KISS system
Everyone's always talking about the KISS philosophy, well here it is applied to washing your car. This is a Bubba-proof method of measuring your, Car Wash Solution to Water ratio using inexpensive common household items you probably already own and have lying around the house.
First, you need to read the directions for the car wash solution you use and find out what the manufacture recommends for product usage. In this example, we're using Meguiar's Gold Class Car Wash and Shampoo and according to the back label, they recommend using,
1 ounce of car wash solution per gallon of water.
Old Style Math
This means if you're going to fill a 5-Gallon bucket with approximately 5 gallons of water you're going to want to add 5 ounces of car wash.
Developing a Repeatable Routine
The idea with mundane simple tasks is to make it easy on yourself to do the task quickly and easily without any obstacles or hassles. So what you need is a system approach.
The Dixie Cup Method
To make things fast and easy each time you want to wash one of your cars or one of your customer's cars, and to insure you don't use to little or too much car wash soap, use a Dixie cup or some similar plastic cup to pour your car wash soap into and measure out just the right amount of soap.
What to do
Use an ordinary kitchen measuring cup to measure out 5 ounces of water, and then pour this water into a 16 ounce Dixie cup.
Next, carefully marked the inside of the cup in a couple of places where the water level filled to with a permanent black marker and then pour the water out and finish drawing a line around the inside of the cup to match the marks you made.
This will enable you to simply pour the car wash solution out of the car wash bottle and into the Dixie cup until it fills to the mark you've made inside the cup.
Quick, simple and accurate.
Next, simply pour the car wash solution to the water... note the bucket is contains about 4.5 gallons of water.
Because car wash solutions like the Gold Class Car Wash and Shampoo are very thick in their consistency, in order to remove all of the car wash out of the cup and into your bucket of water so as not to waste any car wash and to leave your Dixie cup rinsed, clean, (not coated with car wash solution), and ready to put away, dip the Dixie cup into the bucket of water and swish it around.
Then after swishing it around, pour the water/soap solution back into the bucket...
When you're through, you can store the Dixie cup and use it again the next time you wash your car.
You can store your Dixie cup upside down over the top of a jug of car wash to help prevent dirt from accumulating in the cup. Be sure to rinse the cup out before using it again for future washings. You can never be too careful.
Now we're ready to wash any car using the 2-Bucket Method with one bucket filled with clear, clean rinse water and the other bucket filled with our car wash and water solution mixed at the correct dilution level.
Here's a little insight...
Fill your soap solution bucket with water first and then add the soap and mix it around with your hand. Why? If you measure out enough soap for 4-5 gallons of water, then you need 4-5 gallons of water to dilute the soap into, follow me?
If you pour the soap into the bottom of an empty bucket and blast it with water, you will get a bucket with about 1-2 gallons of water and the rest will be suds. Now your dilution levels are all whacked-out and you're using too strong of a soap solution.
The goal is to have a full bucket of water with the soap equally dispersed into the water. If you can accomplish this, you can easily create suds after the fact with a quick blast of water or by using your fingers to agitate the soapy water.
Hope this helps to some level...
Am I right?
(Yeah I'm right)
The KISS system
Old Style Math
What to do
